Parts questions
67cspowerwagon
City: maple valley
Parts questions
Post by 67cspowerwagon »
Ok I been thinking of sell some parts off drums Dana 44 front ends 60's rears 435trans and 201's good running 383 with all parts to swap a small block to big block is their people that want this stuff? in western washington? ideas?
Re: Parts questions
Make a list, add prices and your location and then post the stuff in the "Trucks and Parts for sale" section of the forum.
67cspowerwagon
City: maple valley
Re: Parts questions
that why I ask the question here Is what do you guys think it worth?
Re: Parts questions
67cspowerwagon wrote:that why I ask the question here Is what do you guys think it worth?
Sorry, I mis-understood what you meant. Unfortunately, I cannot answer what it is worth. List the stuff as Best Offer? :thinking Good Luck! :salut
Re: Parts questions
67cspowerwagon wrote:Ok I been thinking of sell some parts off drums Dana 44 front ends 60's rears 435trans and 201's good running 383 with all parts to swap a small block to big block is their people that want this stuff? in western washington? ideas?
All depends on the condition of these parts. On drums, you'd need to verify if they're still within
spec. or turned beyond further use. You'll be playing to a local market on the axles, trannys and
t-cases. Gear ratios of axles will determine their worth as well.... Probably not a ton of guys out there
dying for a pair of axles with 4.88 gears... but the 4.10 or 3.54 geared axles might be something a
guy would drive to your location to pick up. :2cents
In short.... Yes. There are folks who want these parts. It might take you a good while
to sell them though due to them being "Pick Up in WA" parts.
Do you have a pair of lift blocks for a pre-'69 W100/W200 rear axle?? That's something
I could use.... :idea :Thumbsup
lbman
City: Deming
Re: Parts questions
Post by lbman »
any parts for a 63W200 Ambulance body parts that is
Id love to have the 383 conversion how much do you want for it? what shape is it in, IE. compression? I live in Deming WA.
I also need a transmission/drive line brake cable.
LB
Roxyflash
City: East Moline
State: IL
Re: Parts questions
Post by Roxyflash »
Is this a hyd bellhousing 383?
