NP420 needs rebuild. Should I just go w/NP435?
- City: 95658
I have a 64' W200 that needs a new transmission. I have a 73' NP-435, but it's 4" longer than my NP-420. Did the mid 60's trucks that came from the factory with NP-435's have a shorter tail shaft set up or do I need a shorter driveshaft in between my transfer case? What would you guys do?
Re: NP420 needs rebuild. Should I just go w/NP435?
Does the '73 NP435 have a 23 spline input shaft and a tail shaft mount on it?NewcastleHoward wrote:I have a 64' W200 that needs a new transmission. I have a 73' NP-435, but it's 4" longer than my NP-420. Did the mid 60's trucks that came from the factory with NP-435's have a shorter tail shaft set up or do I need a shorter driveshaft in between my transfer case? What would you guys do?
Your NP420 will have a 10 spline input shaft.
- City: 95658
Yes it's a 23 spline with a u-joint out back.
You can't use that 23 spline input shaft with the older hydraulicNewcastleHoward wrote:Yes it's a 23 spline with a u-joint out back.
clutch clutch components. I'm not sure that you can swap out
input shafts.... Perhaps someone else can chime in on that.
- City: 95658
Does anyone in Northern CA have either a good 420 or 435 for a PW?
Check with Terry [PwrWgnDrvr].NewcastleHoward wrote:Does anyone in Northern CA have either a good 420 or 435 for a PW?
- Roxyflash
- City: East Moline
- State: IL
I bought a hyd bellhousing for a big block it had a 23 spline clutch in it so I guess it can be done.Im using a 10 spline clutch in it.
contact dave at uglytruckling.com he is in Medford OR I bet he has oneNewcastleHoward wrote:Does anyone in Northern CA have either a good 420 or 435 for a PW?
