power steering
Posted: Sat Jun 01, 2013 6:25 am
by trevor
I found a 70 D200 camper special that has power steering, just wondering if anyone has tried to fab this over to a power wagon? I haven't got a close look yet, this truck buried in the bushes still, going to rescue it today, but I have a 70 W200 and started wondering.
Re: power steering
Posted: Tue Jun 04, 2013 4:18 pm
by jimmy
The guys have talked about this in the past, I'm sure someone will speak up.
Re: power steering
Posted: Tue Jun 04, 2013 5:13 pm
by dodgeboykim
If your going to do a power steering conversion and depending on how close to stock you wish to keep your truck ,It may be best to go a step further and do a full power steering upgrade with a newer style box. Don't bother with the old ram and control valve style in the drag link.
Re: power steering
Posted: Tue Oct 01, 2013 9:51 pm
by BlueManCrew
Hello. New member. I have a 1969 crew cab with W200 68 running gear. How do I find a compatible new steering box like you are suggesting?
Re: power steering
Posted: Tue Oct 01, 2013 11:05 pm
by dodgeboykim
Currently my 66 W100 has a steering box from a 75/77 W100/W200 in it. Used the stock column with a custom steering shaft and mounted the box in front of the axle. If I was to do it again I would probably use the next generation W100/W200 box and do a crossover steering system. My current one works but has bump steer. As I don't put a lot of miles on it I live with it. But it would be easy to upgrade it to the later box as the major mods are (frame/shocks relocated/column) done.
Re: power steering
Posted: Wed Oct 02, 2013 6:11 pm
by OldD200
I've got an 85 Dodge 3/4 ton 4x4 cross steer on my Crew. Works super well.
Scott
Re: power steering
Posted: Mon Oct 14, 2013 9:32 am
by BlueManCrew
Is it possible to get a parts list from you. Did you get this from a wrecking yard? What parts did you have to fabricate? I have the control valve and cylinder parts but they need to be rebuilt. I'm hearing it's not worth it.
I did find some stuff on ebay, but I'm not sure what to look for. See this link for example....
http://www.ebay.com/itm/321223859087?ss ... 1423.l2649
This is one of the last steps for me to get this rig on the road. Thanks!.
Re: power steering
Posted: Mon Oct 14, 2013 10:59 am
by OldD200
I'll try and get some pictures and post them here. If I don't get them today will be at least a week since I'm working out of state. How about giving me your email address so I can send some larger photos.
Scott
