I removed a Factory system from a 71 camper special 2wd.
Will it bolt on to a power wagon? Is the drag link the same length? Tapper eyes same size? Is the pitman arm the same from the 2WD steering box Vs. 4wd?
I have the System for sale and am being asked the question.
Thanks
factory PS question
Re: factory PS question
Thinking it won't swap because for some reason thinking the drag link for the 4wd model is in front of the axle whereas it is behind the axle in the 2wd models. Also thinking the steering boxes are different and located in different positions between the two models.
- pismopowerwagon
- City: Caldwell
- State: ID
I did it to my Powerwagon and there is some mods to be done. It works great, but wont bolt right up.
- surfnuke9
- City: Churchton
Nope. Drag links are behind the axle on D's and W's. W's link is basically straight while the D's link is bent some. Steering box is in same location on both.Johninky wrote:Thinking it won't swap because for some reason thinking the drag link for the 4wd model is in front of the axle whereas it is behind the axle in the 2wd models. Also thinking the steering boxes are different and located in different positions between the two models.
I can double check, but I believe the Pitman arms are different.
Also, the tie rod on the 2wd 100/200 is behind the axle whereas
the tie rod on the Ws are in front of the axle. This would likely
pose an issue for the hydraulic ram.
On the 2wd P/S
systems, there were trapered shims between the axle and leaf
springs as well..... Lots of "stuff" to be aware of.....
![Study :study](./images/smilies/icon_study.gif)
![Turn Pale :pale](./images/smilies/icon_pale.gif)
- Roxyflash
- City: East Moline
- State: IL
I was at Dougs 4 wheeler yesterday they have a factory power assit steering on one of there junk powerwagons i believe it was a w200 looked be be in good condition its still on the truck.Its differant then the d series the control vavle and cylinder are not the same first time i have seen one there in pella iowa
- jimmy
- City: Spokane
roxyflash-
I see what your saying. I was asking the question because I had a D200 PS system for sale and someone wanted to know.
I have ford PS on my crewcab
Thanks for letting me know.
