Lifting a w200 power wagon?
- ricknadine1111
- City: lancaster
anyone lifted a 1969-1971 w200 power wagon? If so how and what do I do?
I just painted my mailbox mopar engine blue and silver
Re: Lifting a w200 power wagon?
Start by replacing the old springs with new ones from EATON then check your height.
How high do you want to go and what are you planning to use the rig for?
73 CJ5 304V-8 Metal Cab
- ricknadine1111
- City: lancaster
I just want a lifted truck once in my life and these trucks look bad @#% lifted. I plan to use it as a regular everyday truck
- crusty
- City: Yelm
I am not the most familiar with the sweptline intricacies, but I have lifted a bunch of trucks. Here's what I have found:
First, have a clear goal. If you want 33s, shoot for 33s. If you want 36s, don't settle for 33s. It will create more work later.
Second, have a clear budget. The lift and tires are only part of the equation. You also need to account for steering corrections, brake upgrades, and (possibly) regearing.
Third, do your homework before you buy anything or remove anything. You don't need to have all the stuff in the garage, but know exactly what parts you will be using before you start.
I would start by verifying what gears you have, as that could save you a bundle right there. In my opinion, 4.10s are good for up to 36" tires. I think that was the tallest ratio in these trucks anyway. I can't help you with steering, but I can say that bigger tires are much different on braking. A good brake tuneup should be considered a minimum. This includes new soft lines (consider braided SS)
Hope all this helps
Hope all this helps
What a mess.
Are you planing on running the stock frontend,or changing to say ,a newer dana 60 and crossover steering.
Good lift that works good = Empty your wallet.
- POWWAG
- City: Maple Valley
This is how the Chevy guys are doing it!
Don
Don
- ricknadine1111
- City: lancaster
I wanted to stay stock but if I did go new what front end would I need?
- crusty
- City: Yelm
You could probably use a dana 44 or 60 that has disc brakes. I am going to use an early 90s cummins dana 60 front for mine.
What a mess.
- 3onthetree
- City: MI
I JUST HAD NEW LEAF SPRINGS MADE FOR MY 65 CREW CAB BY ALCAN SPRING 888 321 0870
6" OVER STOCK IN THE FRONT AND 10" IN THE REAR TO ELIMINATE THE STOCK 4"BLOCK
I'M GOING TO RUN 37"TIRES.
I PUT DISK BRAKES ALL THE WAY AROUND THE STOCK AXLES
- City: spencerville IN
that is scary -that is chevyPOWWAG wrote:This is how the Chevy guys are doing it!
Don
1968 W100 SB 4-speed 318
1968 D200 Custom Camper Special 4-speed 318
2000 Ram 2500 LB 4x4 5.9 auto.
2011 VW Jetta- wifes
2004 Stratus
2008 Avenger R/T
2004 Stratus
2008 Avenger R/T
- City: Hayden, Idaho
- State: ID
Its a suzuki samuri It was off scarysteering.com I believe
1970 war wagon on 38's
1968 dodge D300
1987 w150- slant 6 - soon super 6
14 other dodges?
17 tractors - maybe more I have to go recount.....
'55 coe Ih
1980 M35A2
4 coots
Rokon Trailbreaker
1968 dodge D300
14 other dodges?
'55 coe Ih
1980 M35A2
4 coots
Rokon Trailbreaker
- dirtrider
Superlift still makes full bolt on lift kits for our old dodge's.
Just call and give them a credit card number.
2006 Dodge Cummins Quad Cab
2003 Jeep Wrangler (Trail Rig)
1997 Jeep Grand Cherokee (Wifes Ride)
1971 Dodge W100 short box utiline
1970 Dodge Challenger R/T
- 440SCOUT
- City: reno nv
- State: NV
so does skyjacker, i have their 8inch lift for my 70 crewcab..dirtrider wrote:Superlift still makes full bolt on lift kits for our old dodge's.
- ricknadine1111
- City: lancaster
I need pictures
- Ruckus
- City: Stevensville, Montana
I'm gonna stick my neck out here and say a Dana 44 front axle, be it closed or open knuckle, can't really handle more than 33" tires if you actually want to use it offroad. Oh sure, there are lots of folks out there with big meats on wimpy axles, but you can get on U-tube and see vids of their wheels falling off deep in the mountains. If a 3,000 lb jeep with 35" tires can easily break a 44 front axle, then a 5,000 lb Swepty with a healthy Mopar engine will do it even easier. Of course, prudent driving can do wonders, but most folks get a lift and some big tires and go jumping which about the dumbest thing you can do (don't ask me how I know this). There is nothing worse than trying to "prove" to your buddies how tough your truck is only to have your driveline turn into a pretzel. You could probably get away with 35-36" tires if you kept it real mellow in the engine dept. There is a reason that Dodge didn't offer the 383 on the W300. They only offered the /6 and 318 cause bigger engines tore up the drivetrain too easy under loaded 4x4 conditions (like getting wood etc.). Just something to consider when yer on the freeway at 75 mph...
Just look at Matt's post "went rock crawling this weekend" if you want proof of what I am saying. These trucks are tough, but not near as tough as dear ol Mother Nature. It's a real shame to take a nice old truck and tear it up for no reason.
viewtopic.php?f=1&t=15909
78 W200 crewcab, 68 W200, 59 Willys Wagon, 52 Ford F5 Cabover
- 440SCOUT
- City: reno nv
- State: NV
you can break anything if you try hard enough..
- RussRoth
- City: Vancouver, WA
440SCOUT wrote:you can break anything if you try hard enough..
That is very true. I do think anything over 33" on a 44 with no upgrades is starting to push it, especially if you have a lot of torque.
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
- 440SCOUT
- City: reno nv
- State: NV
The stock axles on those 44 will not hold up ,you are correct.. then once you get some chromo's in there the stock carrier will break, or the pinion gear.. but that is only my experience..
once i replaced that my d44 was fine with the 42's...
also mine was not a rock crawler, and i used an open front dif that probably helped alot also..
Ruckus wrote:I'm gonna stick my neck out here and say a Dana 44 front axle, be it closed or open knuckle, can't really handle more than 33" tires if you actually want to use it offroad. Oh sure, there are lots of folks out there with big meats on wimpy axles, but you can get on U-tube and see vids of their wheels falling off deep in the mountains. If a 3,000 lb jeep with 35" tires can easily break a 44 front axle, then a 5,000 lb Swepty with a healthy Mopar engine will do it even easier. Of course, prudent driving can do wonders, but most folks get a lift and some big tires and go jumping which about the dumbest thing you can do (don't ask me how I know this). There is nothing worse than trying to "prove" to your buddies how tough your truck is only to have your driveline turn into a pretzel. You could probably get away with 35-36" tires if you kept it real mellow in the engine dept. There is a reason that Dodge didn't offer the 383 on the W300. They only offered the /6 and 318 cause bigger engines tore up the drivetrain too easy under loaded 4x4 conditions (like getting wood etc.). Just something to consider when yer on the freeway at 75 mph...
FYI ..Dodge did offer W300s with 383. I have seen two 71s .Both were factory trucks,and I did read the data plates.The red 71 in the sweptline regestry is one of them.It now belongs to Marty ,in Canada.It used to reside in Lewiston Id.
- POWWAG
I think it's all karma! I have a 77 W100 with a built 440 (450 H.P.) and I
decided to go mud racing with it. I thought why change out this 1/2 ton
stuff let's break it first. Lincoln lockered both ends and went racing.
Light duty D44 with the wimpy full time knuckles and a dozen brutal
runs later, no breakage.
Don
Don
