Newbie w/'62 W200
FlyingEagle
City: Denver
Re: Newbie w/'62 W200
Post by FlyingEagle »
When you get under & look at springs, yeah not lifted. Someone said the earlier trucks had different fenders making them look lifted. Or something like that.
Updates:
I got hood hinges off a '70. Now my hood stays up. :clap
I replace my janky rear view mirror w/ one from the '70. :clap
I got the hubs off the '70, just not installed yet. Gotta remove some broken bolts. :thinking Or go back to yard & get the pass side bearing hub.
Oh, battery is crap. Will swap w/ Scout when I sell it.
Scott
Scott
'62 W200 w/LA318, 4spd (rescued from parts truck status)
'49 Chevy 1/2 ton- will drive it til I die
FlyingEagle
City: Denver
Today's progress: I think got everything off the junkyard '70 I can afford. I got the Warn hubs off it, but my pass side wheel hub turned out to have damage. Went back out to yard & grabbed one. Probably should've got both. My pass side drum was in bad shape. Got the drum & hub on! It was raining so I only did pass side.
While I was there I got a throttle control cable. It holds the throttle steady for PTO's or whatever. It bolts to firewall the same as the pedal on my '62. I had to do a ghetto fix on my pedal, so this will be a cool swap.
control knob
control knob
Scott
hoon
City: Youngstown
State: OH
Post by hoon »
Cool truck. My 62 came with a np420 trans, but if you have a newer engine the trans could've been changed also.
62 D300
That throttle control set up would be mighty handy for anyone who has
a '69-'71 truck with an LA318 and LU-2 winch. :clap :Thumbsup
Good score on that!
FlyingEagle
City: Denver
I'm not 100% sure what trans I have. Haven't scraped all the goo off yet. Doesn't look like there is room for the shaft to add a PTO to the trans (pass side). Maybe transfer case? What did the LU2 do? I have a PTO winch setup off an old chevy. I think it is driver side of trans. The PTO itself is one of the cool universal ones with forward & reverse. Take it apart, swap guts around, & put back together.
Thanks, John. I almost left it there. I snagged it on my second trip to the yard.
Scott
FlyingEagle wrote:I'm not 100% sure what trans I have. Haven't scraped all the goo off yet. Doesn't look like there is room for the shaft to add a PTO to the trans (pass side). Maybe transfer case? What did the LU2 do? I have a PTO winch setup off an old chevy. I think it is driver side of trans. The PTO itself is one of the cool universal ones with forward & reverse. Take it apart, swap guts around, & put back together.
A standard set up would include a T-case driven Braden FTD-7 PTO
along with the shafts/pillow blocks that would run up along the left
part of the frame. The [Chelsea] tranny PTOs were also popular. They
do require some shimming depending on what you're working with.
Your truck likely has the NP420 tranny.
FlyingEagle
City: Denver
Thanks guys for info. I am very familiar with SM420 (chevy guy), but not NP420 so I'll do some research. All I can tell you is this has reverse to right & down. A different trans might explain why the tunnel cover is butchered.
Update: I got the flatbed installed! Lot of fun, but I definitely won't be stealing jobs from woodworking guys. I used treated redwood. Will add some kind of front board/headache rack after I finalize my storage plans. Just have to mount the mirrors & taillights and this beast will be roadworthy. I can't wait to see how it does offroad. I hit a local trail yesterday, and had to turn around at a huge rock that you had to go down. My Scout wouldn't have made it back up (trail was in & out) without risk of breaking. I know the PW could do it.
I may have to cut out the boards above the tires, but I jacked it up & it doesn't look like the suspension flexes enough to worry about. We'll see. Oh, the trees are dead because of the Hayman fire in 2002.
my Scout above rock
my Scout above rock
Pike's Peak in background
steeper than it looks
Scott
My LU-2 was driven off of t-case (divorced NP205) on the driver's side. I think the majority of the LU-2's were this way.
FlyingEagle
City: Denver
Finally got my side mirrors mounted & my better tires mounted. Only got to drive it 1/4 mile, but I can tell it has plenty of power. I'm used to a worn out 4 banger. Now I just have to get wipers working & go through brakes.
Scott
powerwagoncrazy
City: Hubbard, OR
Post by powerwagoncrazy »
Lookin' good!
FlyingEagle
City: Denver
Thanks. It's coming along slowly, but I'm having fun. Can't wait to get this baby in the mountains!
Scott
FlyingEagle
City: Denver
One last update & I'll let this thread fade.
I finally took it out for a maiden voyage! Drove about 15 miles to buy a 318 off craigslist. The truck did very well. I'm surprised how easy it is to steer. Suspension is pretty stiff, but it is a 3/4 ton. Still having carb issues, but that is why I bought the 318.
It is about an '80. It has electronic ignition and 4 brl intake. The carb is a Carter AFB. Supposedly the engine only has about 40k miles on it. It's possible, I guess. Too bad I had gone to junkyard & picked up an electronic distributor & 4 brl intake last week. Tomorrow I will put the junkyard 4brl intake & Carter on the 318 in the truck. I'll save the new 318 for a spare & maybe soup it up a little.
Scott
