for the dana 70 wheel bearing nut ?
on my '93 dana 60 it's 50ft/lbs, but on my '63 w300, everything locked up way before i got to 50.
thanks
what is the torque
- gabbagabbahey
- Jeffc
Assuming it is the closed nuckle axle,
It looks like have a bearing adjustment independent
of the drive flange since it used tappered bearings
the drive flange is bolted outside, for the nuts on the drive flange bolts to drum book gives 30 to 35 Ft Lbs, so 50 would be a little high.
Never done one myself, just out of my 62 book......
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4sp od
Old iron or no iron!
One size does NOT fit all!
62 D100 225 3sp lwb
- wideblock
- City: las cruces nm
- State: NM
all the wheel bearings i have ever installed wernt torqued. i run the nut in till it was snug to seat the bearings, then backed off to the next cotter pin hole, or about 1/8 turn if you got the lock tab washer. ![Thumbs UP :Thumbsup](./images/smilies/icon_thumright.gif)
Trey
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
- gabbagabbahey
>>all the wheel bearings i have ever installed wernt torqued. i run the nut in till it was snug to seat the bearings, then backed off to the next cotter pin hole, or about 1/8 turn if you got the lock tab washer.<<
That's going to run them a little loose. Taper wheel bearings should have 35-40 in-lbs of preload. The bearings should first be run down tight to force the grease out, so that a false reading doesn't result. Then loosen them up and retighten them snug. An inch-pound torque wrench can be used on a wheel nut to test preload, or if you don't have one, give the tire a good hard spin. Preload is correct when the tire makes one complete revolution (from the point where you release it) and stops. If it spins more, tighten them a bit; if it spins less, loosen them.
