Guys and Gals,
I know that this subject has been approached a couple times and I have looked at some of the previous "frame swap" posts.
This is what I pose to all you swepty heads out there.
I want to go diesel on my 1964 D200 (converted to W). I really think that the easiest way for me to go is to do a body swap onto something like a 2500 ext cab Cummins.
What I am looking for is... Would this vehicle be the best option to fit the 146" wheel base that I have???
Discuss!!
Frame/Body Swap Opinions
- thembsnyder
- City: Decherd
Re: Frame/Body Swap Opinions
Easiest????thembsnyder wrote:... I really think that the easiest way for me to go is to do a body swap onto something like a 2500 ext cab Cummins....
Nothing easy about any way to go!
1965 W200 Cummins Project:
http://dodgesweptline.org/phorum/read.p ... #msg-11534
- thembsnyder
- City: Decherd
Sorry I kind of left myself open for that one..."easiest" is a relative term. It would be more "effective" for me to do a body swap..how is that??
Also, would it be more efficient for space in the engine bay to go with a gas or diesel engine?
It has been done both ways, a frame swap and swapping all the newer components to the old frame. There is a lot of information here about what is required for each one.
- City: Glenpool
You could buy all if the parts to make your D200 a W200. There are lots of parts trucks without titles to be had for a decent price.
- thembsnyder
- City: Decherd
I already have a D200 converted to a W200. I am unsure if it was an upgrade or a frame/body swap.
This is just something that I have been considering, probably never gonna happen.
I was just more wondering what vehicles would make the best candidates for a frame/body swap for a 1964 D200(W) Crew Cab.
- EarlKann
- City: Riverside
IMO, this depends on your skill & fabrication ability, or willingness to pay big $$$$ to a shop. You will have to alter the wheelbase somehow, either shortening (easier) or lengthening the frame, or moving the suspension mounts. I did a body swap of a 73 Ford Courier body onto an 83 Toyota 4x4 chassis. I was able to adjust the cab placement so the front axle lined up with the wheel wells, and then I cut off and moved the leaf spring mounting points on the rear to fit the bed. I did have to lengthen the frame a little bit as well. If you can measure, cut and weld all of this is pretty easy. I did it all with a 110V wire feed MIG.
