Air Compressor
Air Compressor
I have a 29 gallon husky right now. The compressor died last night, but the tank is only 2 years old. When I get a new one, hopefully Friday, can I use this take as extra air storage? All the relief and reed valves on the old tank are still good. I do realize that this would make the compreesor run longer, but wouldn't it also make it run less?
- mopardwh
- City: Longview
Re: Air Compressor
Sure you can. It will run longer initially, or when you drain the tanks. Otherwise it shouldn't make a difference.
Re: Air Compressor
Just to be safe, take a look at the duty cycle on the compressor motor.
