Fan blade failure, never seen this happen before
garyo
Post by garyo »
Blade on a factory fan bent. Motor is tied down, plenty of clearance all around. I've never seen this, any ideas what would cause that?
Gary
1970 Dodge Sweptline Plum Crazy Purple
I sell glove boxes and a few other reproduction parts.
Cageman
City: Bismarck
Re: Fan blade failure, never seen this happen before
Post by Cageman »
Something from the road bounced up into it and bent it.
garyo
Post by garyo »
It was sitting in the garage when it happened.
Gary
russ446
City: iroquois,on,ca
Post by russ446 »
i lost blades off a couple fans on a new yorker i used to have. as i remember i had to change the clutch fan. it was siezing up.
moparman64
City: prineville
Post by moparman64 »
i dont know, could it be a harmonic balancer? ive lost a blade in my old 78 dodge 4x4 with a 440 in it. went right through the hood. but i was pullin a pretty steep grade and runnin a pretty high rap on the motor. as i recall it too was a clutch fan.
life is too damn short to have a boring ride!
64 D-100 short wide /6 with 3 on da tree!
96 dodge neon sedan SRT-4 2.4T swap
78 mercury marquis wagon, 514 stroked big block
78 ford pinto 302/aod 4 speed
garyo
Post by garyo »
Clutch is new for whats that worth. It feels fine. This one has my puzzled. I told someone I think the truck has demons as I keep fighting the same problem areas over and over.
Gary
Daddiojoe
Post by Daddiojoe »
Gary--
As far as demons go, if I was a demon, a place called Arcanum would certainly be attractive.
garyo
Post by garyo »
the definition of Arcanum, a secret place.
Demons have been hovering around here alot it seems.
Gary
Cageman
City: Bismarck
Post by Cageman »
Is the water pump shot, allowing movement?
garyo
Post by garyo »
Water pump is fine.
Gary
Oxdodge
City: Albuquerque
State: NM
Post by Oxdodge »
any missing cats? :pale
2004 Chevrolet Impala
1996 Pontiac Bonneville
1966 Ford Mustang
1965 Dodge D100
1973 Humanoid Caucasian
...all made in USA
weezer
City: Conway, SC
Post by weezer »
Oxdodge wrote:any missing cats? :pale
You know, I thought of that, too. When I was little my Dad worked late nites some times and, after he came home, when the weather was cold, the cat would climb up in the fan shroud where it was warm. Mom learned real quick to bump on the hood with her fist a couple of times before she started the car the next morning. Now some 45 years later, Mom still has cats and I still bump on the hood when I get ready to leave her house in the winter.
garyo
Post by garyo »
No cats are missing, none around.
Gary
