I found some information about IFS swaps on another site. It applies to 48-60 Ford trucks but it should be somewhat similar for our trucks.
http://www.ford-trucks.com/article/idx/10/0/
If you read part one first it will list the attributes of the original suspension,steering and brakes. Each numbered section applies to a different suspension donor.
This may be a bolt-in IFS crossmember for a Sweptline. http://www.gibbonfiberglass.com/trucks/torsion_kit2.asp
The kit mentions a 61-63 Ford which may be the same frame width. The other trucks mentioned may be the same too. I don't have any to measure but I'll look around.
IFS information
