1969 W200 Power Wagon
Wildergarten
City: Los Gatos
Re: 1969 W200 Power Wagon
Post by Wildergarten »
Specwar762 wrote:
Sun Oct 13, 2019 9:25 pm
Is it not just one of the standard u joint straps that Dorman sells?
On the big 5380 yoke (4.50" across), the driveline guy with whom I'm dealing says the straps are unobtainable. He's been in the business for 40 years. '68 and earlier they used the 5380 for the heavy duty trucks such as the Camper Special and for the big block. On a '69 I wouldn't be certain, so I may have spoken out of school depending upon what you have. So it depends upon whether they used the (optional) big yoke.
Specwar762
City: Fort Worth
Post by Specwar762 »
From what I can tell, the 1969 Dana 60 rear axle uses a 7260 style yoke. I ordered some straps to see if they will fit.
Wildergarten
City: Los Gatos
Specwar762 wrote:
Mon Oct 14, 2019 8:31 am
Seeing as you lost a strap, take a close look at that yoke, as it might have been damaged as it came out. I have a '69 W200 with a rear axle that is no good I am going to part out. So if you need a yoke I'll pop it off and give it a look (don't know about the seal journal). If it's good, I'd be happy to just send it. That truck also has a relatively low-milage driveshaft with a later model sliding yoke, but I'd have to sell that because of the trouble shipping it.
Specwar762
City: Fort Worth
Wildergarten wrote:
Mon Oct 14, 2019 9:10 am
Man I’d really appreciate it if I need it. I will let you know. This thing is going to be so much easier to work on when it’s on concrete and not 2 hours away.
Wildergarten
City: Los Gatos
Specwar762 wrote:
Mon Oct 14, 2019 10:37 am
I'll be here.
Specwar762
City: Fort Worth
Are these rust spots about normal for a truck that’s been sitting outside this long? I’d assume I can cut and replace these areas with sheet metal?
Its totally common for an ice cube to melt away sitting outside.
Specwar762
City: Fort Worth
Ripped out the carpet and vacuumed it out.
I'm assuming this is the dreaded common cab mount rust? I'm assuming I could just cut that area out and weld in some metal to fit it up? I don't care if it looks pretty or is correct.
No, not the common "cab mount" rust. Its the common rotted floors, rotted rockers, rotted steps hell, and more. So far, I haven't seen even ONE panel on that truck I wouldn't send to china.
Your uncle is giving u the truck to clean up his property for free.
Wildergarten
City: Los Gatos
PwrWgnDrvr wrote:
Sat Oct 19, 2019 7:12 pm
It's dry enough in west Texas he should be able to find something better.
Specwar762
City: Fort Worth
A few more pictures. Sprayed the floor board with some rust converting primer just to clean things up a bit and stop any surface rust.
By north east rust belt standards..... you've got a relatively decent truck. :dance :Thumbsup
If you basically were given the truck for helping your uncle spiff up his property and if you're
not trying for a "concours" restoration.... dump a bit of money in it and make a driver. :2cents :Thumbsup
That light duty rear Utiline bumper looks remarkably straight for being a military... and then a
civilian truck. That's probably $350 worth of bumper. :clap
Wildergarten
City: Los Gatos
Now that you're there, I have some part numbers for you, but I would need to know if the yokes you have are the older 10-spline design or not (as mine are).
Dale
City: Middlefield
State: OH
Post by Dale »
I agree that by "The Great Rust Belt" of America, that even we see this truck, makes it a fine truck! Looks like it has manual lock out hubs up front too. I would cut those floor pans out, and go over the cab and bed mounts.
1971 Dodge W100
Specwar762
City: Fort Worth
Wildergarten wrote:
Sat Nov 02, 2019 12:38 pm
I’ve already got the u joint replaced and the straps back on it.
