Mechanical pump leak
Chuko
City: San Diego
Post by Chuko »
I’m currently having an issue with my mechanical fuel pump. Well there’s seems to be a little hole on the bottom side of the pump is that supposed to be like that open like that fuel drips out of it when I have the truck running somebody tell me why
Re: Mechanical pump leak
The diaphragm inside is split. You need a new pump. Its not fixable. The hole is a vent and is supposed to be there.
Chuko
City: San Diego
Post by Chuko »
Thank you just Purchased a new mechanical pump quick question I have a slight 6 225 I went from a one barrel to a four barrel intake and carburetor It turns on but when it’s time to push the gas it like sluggish like it doesn’t want to rev do you know what is that
Chuko wrote:
Tue Mar 23, 2021 3:42 am
Its probably associated with the fact that you're dumping about 4x the
normal amount of fuel into the engine.
sweatybetty
City: s.w.
Post by sweatybetty »
Check your spark plugs. Probably sooty black. If so, too much carb/fuel
Chuko
City: San Diego
Post by Chuko »
I’m having problems with my truck it cranks but take like 3 try’s to turn on any body have any idea what can be going on
Chuko wrote:
Mon Mar 29, 2021 12:44 am
Is this the same truck you say "Runs Great" in a For Sale ad? :thinking
Chuko
City: San Diego
Post by Chuko »
The truck runs great it’s getting it to turn over now that’s the problem
