under bed gas tank
- City: mesa
- State: AZ
under bed gas tank
Does anyone know of a gas tank that will fit in the spare tire position under the bed and has a top filler neck so it can be refueled from inside the bed . Has anyone tried the chevy tank from LMC?
Re: under bed gas tank
Try the site search function on this site. There is an abundance of informationvabchmopar wrote:Does anyone know of a gas tank that will fit in the spare tire position under the bed and has a top filler neck so it can be refueled from inside the bed . Has anyone tried the chevy tank from LMC?
on tank relocation.
- slick
- City: Tucson/AZ
- State: AZ
I copied Calmauzy and used a mustang tank. viewtopic.php?f=5&t=20551&start=20#p151667
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
- City: mesa
- State: AZ
Thanks for the link, You put that tank all the way in the rear of the frame. I was trying to place a tank in between the shock tower and the next frame cross member on my 65 d100 short bed. But I will look at your idea. Thanks again.
- HEtkind
- City: Johnson City, Tennessee
When I was having trouble with the tank in the Town Wagon, I started looked at the JAZ fuel cells. You can order them by size and by filler position and I am pretty sure we can get them with the correct sender for MOPAR AND place the filler almost anywhere we want. I was looking at about $500 for the tank, filler, fitting and mounting for the TW. I haven't done it yet, I got the original tank repaired.
Howard
Howard
Howard
62 Dodge D100 Town Wagon
62 Dodge M-37
68 Dodge D100 Utiline
2007 Dodge Ram 1500ST
62 Dodge M-37
- longbed67
- City: woodlands
i used one from a 70 challenger works ok
- City: mesa
- State: AZ
FYI, I have successfully installed the LMC under the bed gas tank kit for a 63-66 chevy in my 65 d100 short bed. I had to move the aft crossmember back 5 inches to make room, this is not that hard of a task, this crossmember is rivet in and the lower hole when you move it aft is already drilled in the frame.
Pictures please.Where is the filler?
- City: mesa
- State: AZ
Every photo I try to post says it's too large to upload the file. The filler is in the bed, with a pop-up filler tube that will be in the bed, Bed is not back on the truck yet If you want photos send me a private message and I will send you some.
- City: mesa
- State: AZ
here are some photos of the truck with the tank installed
- Attachments
- IMG_20150405_144221_205%20%28Small%29.jpg (54.71 KiB) Viewed 3464 times
- City: mesa
- State: AZ
tank can't be seen
- Attachments
- IMG_20150502_113706_514%20%28Custom%29.jpg (54.46 KiB) Viewed 3464 times
- City: mesa
- State: AZ
- HEtkind
very, very nice...Now, what is the clearance between the top of the FRONT of the bed and the bottom of the window? I need to get my bed laying perfect...
I have a 68 utiline, short...
Howard
62 Dodge M-37
62 Dodge M-37
- City: mesa
- State: AZ
I have about 2-3 inches of clearance between the top of the tank and the bottom of the bed
The top of both wide and ute beds lines up with the ledge under the window, which is also the top of the door.HEtkind wrote:very, very nice...Now, what is the clearance between the top of the FRONT of the bed and the bottom of the window? I need to get my bed laying perfect...
- HEtkind
Thank you, time to cut oak blocks and get this right...PwrWgnDrvr wrote:The top of both wide and ute beds lines up with the ledge under the window, which is also the top of the door.HEtkind wrote:very, very nice...Now, what is the clearance between the top of the FRONT of the bed and the bottom of the window? I need to get my bed laying perfect...
Howard
62 Dodge M-37
62 Dodge M-37
- City: mesa
- State: AZ
I struggled to get my bed/cab alignment correct. I added spacers to the cab side to get correct. There is no adjustment on the bed blocks,
- 66patrick
- City: Central
Did you build a stainless steel bumper??? I love that! The diamond-tread aluminum under the tailgate is nice, too.
- HEtkind
It has been a struggle to get my truck looking as straight and nice as yours...two summers ago, I had to weld new rear cab mounts in...after of course, fabricating them by hand.vabchmopar wrote:I struggled to get my bed/cab alignment correct. I added spacers to the cab side to get correct. There is no adjustment on the bed blocks,
Howard
Howard
62 Dodge M-37
62 Dodge M-37
- WD
- City: Rosemark
HEtkind wrote:Thank you, time to cut oak blocks and get this right...PwrWgnDrvr wrote:The top of both wide and ute beds lines up with the ledge under the window, which is also the top of the door.HEtkind wrote:very, very nice...Now, what is the clearance between the top of the FRONT of the bed and the bottom of the window? I need to get my bed laying perfect...
Use Osage Orange instead. I have a trunk drying right now to make bed blocks, and another to make bed boards out of. Both of my old Dodges need new wood, and I only want to do either one once. Have been cutting the wood strips to do a cherry headliner in the 69, and a mahogany one in the 49 (to match the armrests/door pulls I made years ago). Decades behind schedule on the 49, only years behind on the 69...
