Hey everyone,
I've been spending the past few weeks on your website bringing myself up to speed and getting ready for my first Sweptline, managed to find what I think was a pretty clean one sitting in Washington and went through the steps to bring it back home to Canada.
1966 D100, Poly 318 w/ 3 speed .. I am told 76,000 original miles.
Given I have imported this vehicle, it's not as simple as just throwing a plate on it .. instead I need to go through the inspection process. I've started to chip away at small things and hope to be in a position to get it on the road in the next month or so,
So far I have done the following:
- Adjusted valve lash
- New plugs/wires and air filter
- New Alt and Battery
- Swapped to Electronic Ignition
This is my "to-do" list:
- New exhaust from manifolds back, going with a simple single 2.25" and Flowmaster 50 Series muffler
- Inspect front wheels bearings (inner/outer) and wheel bearing seals, check condition of front drum brakes, ideally they are OK
- Inspect rear wheel bearings and seals, check condition of rear drums, ideally they are OK. Change gear oil
- Quick oil change
- Inspect kingpins for any excessive "slop" .. cross my fingers that these are OK but given the armount of "crud" built up on the front i beam I would say these could be the original kingpins!
The above should basically cover me mechanically and should result in a nicely "re-freshed" truck ... from there I will need to deal with some of the small items, if anyone has some advice or guidance please don't hesitate to chime in but a few things I have noticed are,
- Interior door handle stripped out,
- Missing arm rests
- Horn disconnected at steering wheel or not working
- Missing wiper arms and wiper blades, motor seems to work good tho .. Just one speed right? Did these vehicles have a washer fluid provision?
- Front marker lights/signals need to be looked into .. not working right now,
- Missing pass side mirror
- Engine Temp and Fuel Gauge don't appear to be working ...
- HiBeam switch toggles on but won't toggle off?
- No interior light and no dash lights?
Anyways, sorry for the long winded intro .. thanks for having me!
Joe
Alberta, Canada
New Truck - Checking in!
Re: New Truck - Checking in!
![Welcome :welcome](./images/smilies/icon_welcome.gif)
Great truck!
--------------The washer reservoir was a bag hanging next to the battery.
--------------I love the style of mirrors you have on it. Everyone wants the other small mirrors. I'd actually trade straight up for what you have (out of my extra parts pile)
-------------probably something to do with wiring behind the gauges or the fuel gauge is fried. It powers the temp gauge
-------------try greasing it so it slides easier
-------------interior light would have a switch, maybe headlight switch is bad?
Welcome to the site!
Desert Turquoise is one of my favorite
colors for these Sweptlines.
Your fuel / temp gauge problem could stem from
a faulty voltage limiter. This condition can potentially allow excessive current [over 5V]
to pass through your instrument cluster.
There is an easy home brewed limiter
you can make.
viewtopic.php?f=33&t=22961
I put one in each of my Sweptlines a few years ago and have had zero issues.
There are plenty of folks here to help you whip this truck back into shape.
you can make.
current (amperage) is measured in amps, not volts.Hobcobble wrote:... excessive current [over 5V]......
![Shame :shame](./images/smilies/icon_shame.gif)
Whoops!.....PwrWgnDrvr wrote:current (amperage) is measured in amps, not volts.Hobcobble wrote:... excessive current [over 5V]......
John![]()
Excessive voltage over 5V.
