Heater Cores Not Available
greendodge
City: SC
Post by greendodge »
Just a note to let everyone know this. I went to O'Reilly auto parts in November and got a quote for a heater core for my '70 D-100. At that time they were in stock at the local warehouse with next day availability. Wellll.... now that it's cold I went back to get one ...NONE in warehouses anywhere and no longer available from factory! That will teach me to procrastinate!! I've also tried Advance (and their other division Car quest) with the same results. There are some on ebay for $88 and up but I've got a new chebby C10 core (still available for 35 bucks) I'm going to try to adapt. I will let everyone know if it works.
Re: Heater Cores Not Available
JimE
City: Glendale,
Post by JimE »
Check with Summit and Jegs. Jim
03 Hemi Ram 2500
nytemuvr
City: Rio Linda
Post by nytemuvr »
greendodge wrote:Just a note to let everyone know this. I went to O'Reilly auto parts in November and got a quote for a heater core for my '70 D-100. At that time they were in stock at the local warehouse with next day availability. Wellll.... now that it's cold I went back to get one ...NONE in warehouses anywhere and no longer available from factory! That will teach me to procrastinate!! I've also tried Advance (and their other division Car quest) with the same results. There are some on ebay for $88 and up but I've got a new chebby C10 core (still available for 35 bucks) I'm going to try to adapt. I will let everyone know if it works.
http://www.amazon.com/s/ref=sx_as?keywo ... 2------5-1
Butch Romig x 2 :idea :2cents
greendodge
City: SC
Thanks for all the help. The parts store manager showed me the e-mail he got from the factory which stated there were none available and no plans to manufacture more at this time. Now they're out of stock at Amazon too. I suppose when the existing inventory dries up and prices get up over $100 they will magicly become available again?? I used a new (still available for under $40) heater core from an 84 c-10. It was the same size so I soldered the brackets from my old one on ~ tweeked the inlet/outlet tubes a bit and voila cheap (new) heat!
nytemuvr
City: Rio Linda
Post by nytemuvr »
greendodge wrote:Thanks for all the help. The parts store manager showed me the e-mail he got from the factory which stated there were none available and no plans to manufacture more at this time. Now they're out of stock at Amazon too. I suppose when the existing inventory dries up and prices get up over $100 they will magicly become available again?? I used a new (still available for under $40) heater core from an 84 c-10. It was the same size so I soldered the brackets from my old one on ~ tweeked the inlet/outlet tubes a bit and voila cheap (new) heat!
Amazon says they have one left as of 3/8/15. Might be a return or inventory mistake.
Handygun
City: St. Louis
State: MO
Post by Handygun »
You could have a radiator shop fab one up
dogma44
City: nipomo
Post by dogma44 »
heater cores are just little radiators. I have installed/modified "other" cores to fit. you could too.
