aluminum grill
beastman
City: La Center
aluminum grill
Post by beastman »
Hi guys, i've stripped the anodizing off my grill and sanded it with 400 grit, and am now in the process of brushing it with a scotch bright to give it a brushed look. My question is can i clear coat it and have it not chip off?
gyman98
City: Saskatchewan
Re: aluminum grill
Post by gyman98 »
There's a few products out there, one I like is Por-15 Glisten PC. There's also permalac, imeron and everbrite. Probably best to do a few google searches and see which one you like the best
cudaboy
Re: aluminum grill
Post by cudaboy »
How did you get the clear anodizing off ? wait a minute, let me rephrase that question.
What method did you use to remove the clear anodizing from the aluminum grill ?
beastman
City: La Center
Re: aluminum grill
Post by beastman »
i sprayed it down with oven cleaner, let it soak for 30 minutes and hose it off really well :Thumbsup
cudaboy
Re: aluminum grill
Post by cudaboy »
well, cool ! Thanks for the tip. I've heard folks talk about using red devil lye, but didnt get clear instructions, and part of the story was that the real trick was knowing how long to leave it in the mix. Too long, and the lye would eat up the aluminum. Scary stuff to be learning on.
Re: aluminum grill
So, what is the purpose in doing this?
beastman
City: La Center
Re: aluminum grill
Post by beastman »
my grill had dents and looked like crap, dull finish, so i fixed dents and wanted the brushed aluminum look so i stripped the anodizing, scotchbrighted it and now i gotta clear coat it. just for looks
Dood
City: Shoreline
Re: aluminum grill
Post by Dood »
Can you post up us a picture?
beastman
City: La Center
Re: aluminum grill
Post by beastman »
there should be a pic or two in my build thread, none as a close up though. i'll go out later tonight and get a more detailed pic of it for everybody
cudaboy
Re: aluminum grill
Post by cudaboy »
Doc, the purpose of removing the clear anodizing is to polish the aluminum. After that it needs to be coated to keep it from oxidizing.
1964ShortyD100
City: Lake Oconee
Re: aluminum grill
Post by 1964ShortyD100 »
The grille looks awesome. What oven cleaner did you use? I don't know if it matters or not, but I've got some Easy Off laying around here that I'm going to try. :lol:
beastman
City: La Center
Re: aluminum grill
Post by beastman »
i used easy off heavy duty. its 100% complete. i'll try and remember to post a pic on my thread tonight.
