I have a rather odd problem. I can grease all the zerks on my truck except one, and its really annoying me. When I try to grease the zerk on the front of the leaf spring, it just won't let any grease in there. I pulled the zerk off and it is clean, so its not the problem.. Anyone had a problem like that.
Oh also, when I greased everything else, a lot of rattles went away but there is one really loud rattle left and I highly suspect that it is that joint on the leaf spring, so it needs grease..
Matt Gilbert
zerk..
zerk..
66 D-100 long bed swept
Shearingmatt@yahoo.com
- wideblock
- City: las cruces nm
- State: NM
matt, did you try pumping grease thru the zerk while it was off the truck? it may visually appear clean, but the check ball may be stuck
Trey
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
I agree with wideblock there is a possibility that the grease zerk is to blame. There also may be the fact that the bushing has galled the pin and closed up the grease hole. It also could be that the grease has set up in the pin causing it to not take any grease. You could try jacking up the frame taking the load off of the pin and have someone put a grease gun on under pressure and then hit the spring eye with a large hammer. See if that works. The other option is to heat the pin/spring eye up with a torch and then try to grease it. If all else fails the last option is to remove the pin and check the condition of it and the bushing.
Hope this helps,
Ken
Hope this helps,
Ken
Yup, pulled the zerk off and grease goes through it great. SO I'll jack it up, whack it see if that makes any difference. IF it don't, I'll work on taking it apart sometime...... hopefully soon..
THanks a ton guys!
Matt
THanks a ton guys!
Matt
