Brakes problem, Help!
RAYMAN
City: Gifford
Post by RAYMAN »
I have a stock w200 that I upgraded with a brake booster from a d200 camper special. After the upgrade the brakes have been self adjusting to the point of locking up. I have put in new adjusters and new springs with new shoes but the problem still remains. What else could it be? Please help.
Im old enough to know better, but young enough to do it anyway.
Re: Brakes problem, Help!
Check push rod adjustment going into master cylinder.
nutz
City: phillipburg
Post by nutz »
did you do rear brakes at the same time
if so could have swapped self adj from one side to other ??
Jim100
City: Kalamazoo/MI
Post by Jim100 »
I had weird brake pulling and locking and it was the adjuster not making good contact with the notched "star" wheel. I don't know why but I tweaked the little lever and even filed it a little edge and it solved it.
Not sure this is what you have but worth a look.
Im with dodgeboykim. pushrod into MC needs to be backed off a hair
Kaegi wrote:
Tue Oct 20, 2020 10:16 pm
I'd look here too. I've been through this same issue.
RAYMAN
City: Gifford
Post by RAYMAN »
I'm going to check that tomorrow. Does anybody know what the proper adjustment should be?
RAYMAN wrote:
Wed Oct 21, 2020 9:21 pm
Trial and error. Trial and error. Small adjustment's at a time till its correct. :thinking :thinking
To fix my issue, I backed off the adjustment enough to allow the
piston to rest against the stop and then went another 1/4 turn so
I could jiggle the adjustable rod slightly. I haven't had any issues
since. :clap
thats perfect. don't need much clearance.
RAYMAN
City: Gifford
Post by RAYMAN »
Does anyone have a good part number for brake drums i think that is playing a huge part here. I adjusted the pushrod and i still have the same issue.
Wildergarten
City: Los Gatos
Post by Wildergarten »
RAYMAN wrote:
Fri Oct 30, 2020 7:21 am
Raybestos quit making them late last year.
RAYMAN
City: Gifford
Post by RAYMAN »
Wildergarten wrote:
Fri Oct 30, 2020 7:57 am
Do you have the part number i think i have found one but dont want to just chance it.
Wildergarten
City: Los Gatos
RAYMAN wrote:
Fri Oct 30, 2020 8:01 am
Here is all I have for 61-68:
W200 Front: 12170-C
W200 Rear: 12171-C Max ID 12.210" (+0.090" allowable, 0.045" cut)
Bendix PDR0183
Bendix 140183 (US made)
Raybestos 2949R Canada
Turns out the numbers are different for '69-74 and some of them ARE available. Unfortunately, the numbers are for various types of axles and you'll have to match the styles and specifications to your truck.
when they lock up have you jacked it up and checked to see if its all 4 wheels or just the front, rear or one wheel?
I'm assuming you've replaced all of the rubber hoses as well? :thinking
RAYMAN
City: Gifford
Post by RAYMAN »
Yes, I have replaced the rubber lines. the only thing i reused was the steel lines. It is usually the fronts first then the rears. if i back the brakes on the front off then the next day the rears will lock up.
Are you saying that when they lock up the only way to release them is to back off the adjusters? And then after awhile those same brakes lock up AGAIN and you AGAIN back off the same adjusters? If that is the case, it is NOT a hydraulic issue NOR a pushrod issue. it is an ADJUSTER issue!
RAYMAN
City: Gifford
Post by RAYMAN »
I have all new adjusters and shoes and springs. I think the drums are worn so much that when i step on the brakes it pulls the adjuster cable before the shoe hits the drum. I am trying to locate drums now. Does anyone know if the 72 -75 drums are the same. they look really close online.
I just looked in the FSM brakes section. Under troubleshooting there is NO condition mentioned where the adjusters lock up the brakes. In the short section on the adjuster, it gives a method for checking their function. Get an FSM and study that. Note: the adjusters operate ONLY when applying brakes while moving in REVERSE. I have never experienced or heard of oversize drums causing a condition like this.
Look back at your history. If this started AFTER the booster upgrade, but the drums are still the same, why did it not happen BEFORE? Did you put new adjuster cables in that are a wrong length? Are you absolutely positive the adjusters are on the correct side? One is for the right, one is for the left. If backwards, they will definitely lock up the brakes.
