hmaynord wrote:OK. I agree the ammeter gives you better information. That just gets away from the point I’m trying to make.
As I’ve said, my goal is reliability. Here is my point: is that better information worth the costs? Those costs are (1) a longer charging circuit, which means some voltage loss when those amps reach the battery; and (2) more connections in that charging circuit, which means (a) more points of voltage loss, (b) when the alternator is outputting high amps, more points of heat generated, and (c) more points of possible failure.
So, for me, it’s an easy choice to go with the voltmeter, even though it will take me more time to realize the charging system has failed. That time is not critical, because I have the battery as a backup. It’s not the same as water temp and oil pressure, where I absolutely want to know those failures immediately.
I guess what I would like is a voltmeter that swings 90 degrees between 10 and 16, rather than 8-18. Then, a failure would be more obvious. I’d just have to get used to continual small movements of the needle being normal.
The statement on costs is incorrect.
1. The longer charging circuit is irrelevant if the wire is sized correctly.
2. Proper connections add negligible resistance to a circuit which causes negligible voltage loss and heat generation.
Even in a charging circuit with more resistance before the battery (longer piece of wire) the battery will fully charge. It only reduces the time for a full charge. IE, look at the puny (high resistance) wire used on the leads of a bench top battery charger.
With an ammeter, the gauge sits in the center on the 0 line. With a running engine in the daytime, no lights, fan, etc, a failed charging system will be visible immediately. Not so with a voltmeter. In fact, it is difficult to monitor charging with a voltmeter before its too late. U'll find out the next time u park and it won't start. Even an idiot light is better than a voltmeter for monitoring the charging system.
Been driving swepts daily for 40 yrs this coming April. NEVER had a an ammeter problem in ANY truck EVER!
42 WC63 6x6
59 D500
parts truck
61 D100 392 hemi project
62 W300
62 D400 dumper
parts truck
63 D100
parts truck
63 D200 Crew Ute 413 NP420
parts truck
64 D100 Ute
64 D100 CSS Ute
65 D100 CSS Ute
66 D100 CTD NV4500 Daily Driver
66 D300
parts truck
66 W300
parts truck
66 W500
66 W500
parts truck
67 D200 CS
parts truck
67 C500
67 D500
chassis/flatbed
68 D100 Adventure 383 727
parts truck
68 W200
68 D400
parts truck
69 D200
parts truck
69 D300 long
chassis
69 W300
parts truck
69 D400 dumper
70 D100
parts truck
70 D200 CS
parts truck
70 W100 383 NP445
70 W200 318 NP435
70 W200 383 NP435
70 W200 Crew 383 NP445
parts truck
70 W300
parts truck
70 W500
parts truck
71 D100
parts truck
71 D100 Adventurer
71 D200 CS
71 D200 CS Adventurer
parts truck
71 W300 rock crawler project
