Motor identification
Strongbuilt
City: Morgan
State: UT
Post by Strongbuilt »
How do I identify What motor is in my 1965 dodge power wagon D-200 4 door Truck. I have a casting number on the front left of the motor but its for my intake manifold...
Re: Motor identification
Is it a V-8?
If so it is most likely a A318 Poly
Strongbuilt wrote:
Wed Jan 31, 2018 2:59 pm
Is the distributor toward the back of the engine? Are the valve covers
scalloped on the lower side and held on with two top bolts? :thinking
Spark plug wires going through the middle of the huge valve cover? :joker
Andy
Strongbuilt
City: Morgan
State: UT
712edf wrote:
Wed Jan 31, 2018 5:32 pm
Is it a V-8?
Yes sir it is a V-8
Strongbuilt
City: Morgan
State: UT
Hobcobble wrote:
Wed Jan 31, 2018 6:50 pm
Yes the distributor is toward the back, I do not know what scalloped means. I will post a picture if it will let me. I think they are help on by multiple bolts though.. :banghead
Strongbuilt
City: Morgan
State: UT
pismopowerwagon wrote:
Thu Feb 01, 2018 9:06 am
No there is a plate with grooves cut out for them to sit in, on top of the valve covers.
Strongbuilt
City: Morgan
State: UT
By the way, thank you
Strongbuilt wrote:
Thu Feb 01, 2018 10:41 am
If the lower sides of the valve cover are jagged and not straight and are held
on with two bolts on the tops of the valve covers, the engine
is likely an A318 Poly. If there are 6 bolts holding the valve covers on, it could
be an LA318.
This is an A series (Poly) 318 looks like. Notice valve covers and exhaust manifolds.
66 W 100 ENGINE.jpg (47.92 KiB) Viewed 568 times
zachkennedy
City: Hamburg
State: MI
Post by zachkennedy »
On the block behind where your starter is... should be an identification there....write the numbers down and gooooooooogggggllllleeeee.... Should tell you right there.
Should be XXXXXXX-XXX-XX
Strongbuilt
City: Morgan
State: UT
It looks identical to the 318 poly above! Thank you so much! 2 bolts holding the valve covers!
