I've found these two reman steering boxes:
1. $327.76 - Manual Steering Model - with Full Spline Input Shaft: https://www.buyautoparts.com/buynow/196 ... ef=2497804
2. $155.18 - Manual Steering Model - with Flat Spot Input Shaft https://www.buyautoparts.com/buynow/196 ... ef=2336387
Of course mine has the more costly #1 type in it. My question is, are these interchangeable? I have a 1968 d200 and from my reading they can come with either type. Can I replace my #1 with a (cheaper) #2?
Thanks!
Manual Steering Gear box - Will this work?
- City: Gilroy
Re: Manual Steering Gear box - Will this work?
I would suggest you contact Bud Thorp ( powerwagon54). He rebuilds them the correct way, so you do it once and move on.
How do I get in touch with Bud Thorp ( powerwagon 54 ) about rebuilding my 66 steering box? Thanks Bigg 209-712-1186
With a PM. Its email like. Log in and go to the user control panel.
- powerwagon54
- City: Washougal
pm sent.....Thanks Wally!!!!!!
- PowerMan
- City: Auburn
I ordered a box from Buy Auto Parts and all they did was paint it and it was a minimal at that. It had more steering play than the worn out original box. They sent me a replacement which had the exact same problem so they were both sent back. I don't recommend them.
Try Bud Thorp the next time.PowerMan wrote:I ordered a box from Buy Auto Parts and all they did was paint it and it was a minimal at that. It had more steering play than the worn out original box. They sent me a replacement which had the exact same problem so they were both sent back. I don't recommend them.
