Are the front beam axles on these trucks “sided” or are they reversible?
Wondering if I need to mark it somehow before I sandblast and paint it or if it doesn’t matter which way it goes back
Front axle question
- City: Cochrane
Re: Front axle question
Axles with sway bar attachment pads maybe so.
Is there any caster built into the pad where they meet the spring or any angle to the king pin holes?
It may be just me, but the axles don't appear 'straight' and have a direction to them like this []-v-[] ... but I would use a chisel to mark the direction if you are concerned.
Thank you Terry!
Thank you Terry!
I have to look again, but I think there is a spindle stop cast in the back side of where the kingpin is......
