318 poly head alignment pin to head
Do the 318 poly heads have alignment pins on the block from the factory ? Mine does not have them and was wondering if it should and where they would be located. Thanks
Re: 318 poly head alignment pin to head
That doesn't really make sense.....allsupj wrote:Do the 318 poly heads have alignment pins on the block....
but guessing at your intended meaning, there are supposed to be pins on the block.
Yah, when I went back to read, it did not make sense to me either. But you got the point. I think I found some blind holes that match on the block and heads. It appears that 5/16 pins about 1/2 long will work, same as a chevy small block. Thanks,
Small block chevy cylinder head dowels work just fine. Same size and readily available.
