Capable Slant 6?
Brudog
City: Richardsville
State: VA
Capable Slant 6?
Post by Brudog »
Hello all.
I have not found much info on towing capacities, etc. With a Slant 6 in my W200 Crew Cab, is there any hope of ever pulling a camper, or a tractor / car on a trailer?
If my pipedream is to use the truck for these truck-like activities, what would you recommend? :thinking
Brudog
City: Richardsville
State: VA
Re: Capable Slant 6?
Post by Brudog »
How much does it depend on the capacity of the rear axle? (Rear Axle is a 4.10 Ratio Dana / Spicer 60; Capacity = 5500 from the tag)
I apologize for the "dumb" questions, as I am not the most knowledgeable when it comes to these things. Haven't really pulled anything with a truck before. My Silverado was used for loads of dirt, mulch and sand only.
Brudog wrote:Hello all.
There is hope.... but with 127hp at your disposal and a 4.10 gear, you'll probably have
a slow journey. I'm sure some here can help you out with GVW / GCVW information.
Brudog
City: Richardsville
State: VA
Post by Brudog »
If upgrading is the recommended suggestion, I would like to hear folks' opinions on what power plant I should upgrade to. We will start by ruling out a diesel conversion at this point, as I know nothing about diesel engines and the conversion would probably be light years beyond my expertise level.
Are there any sufficiently-sized engines that would mount up directly to my New Process 435 transmission? Or no matter what, I will need to change transmissions as well? (And I probably know less about transmissions than I do diesel engines :banghead ) It will all be a learning experience...
Any advice is greatly appreciated. :salut
Brudog wrote:If upgrading is the recommended suggestion, I would like to hear folks' opinions on what power plant I should upgrade to. We will start by ruling out a diesel conversion at this point, as I know nothing about diesel engines and the conversion would probably be light years beyond my expertise level.
Jim,
An A318 or LA318 would bolt right up to your current bell housing.
You would need the correct flywheel and probably a better radiator
to cool a V8 down. That would be the easiest option and it would
get you sufficient power/torque to do what you need to do. :2cents
Macros
City: london
State: SD
Post by Macros »
สมัคร sbobet
abodyjoe
City: s.jersey
Post by abodyjoe »
sure the slant can tow... just may only do 45mph doing it..:)
Jim100
City: Kalamazoo/MI
Post by Jim100 »
As Mentioned above look for a good LA 318. I had a slant six and went with a 318 and it was a pretty noticeable increase in performance and it was a bone stock mild LA 318.
jim
Macros wrote:I apologize for the "dumb" questions, as I am not the most knowledgeable when it comes to these things. Haven't really pulled anything with a truck before. My Silverado was used for loads of dirt, mulch and sand only.
สมัคร sbobet
Where is your question? :thinking
สมัคร sbobet
John, Macros quoted the OP.....
สมัคร sbobet
Macros is a spammer.
Thanks for the heads up you two. :Thumbsup
riffraff
City: Newport Beach
Post by riffraff »
As far as official Dodge specs, the below links to the 1969 Dodge Truck brochures I scanned should answer your questions. Not sure how well the specs work out in the real world, but I think Dodge put out honest info:
viewtopic.php?f=33&t=37948
Let me know it the links are dead, as I know Dropbox recently made some changes that may have impacted the links.
Tom
1969 W100 383/435
