1968 W200 production numbers?
Seeking production data for the 1968 W-200 series. In particular -- this truck. W-200 Camper Special Custom w/383 (factory lift). I think the total production was somewhere around 400 +/-. The only non-stock items are bumpers/winch and the wheels/tires. They are Ford 8 lug/16". Thanks in advance to all who can provide info...and no, it's not for sale, just want to know more about the truck.
Re: 1968 W200 production numbers?
Welcome to the site. Great looking W200.
I'm not sure there was a "factory" lift though. The pre-'69
Ws sat higher than their successors. Unless another
wheel is called out on the data plate, your W likely had the
split ring 16" wheels and 7.50 x 16 tires. Lots of folks ditched
the split ring wheels in favor of the one piece wheels.
Thanks for the reply. I believe the Camper Special version had the "high boy" lift from the factory. The truck had the original tires and the split rims on it. In fact, I have the original spare/wheel still riding along where it was since new. Tire still has the mold "nubs" on it. I replaced them with Ford 8 lugs (16"). Cheers.
Jambo wrote:Thanks for the reply. I believe the Camper Special version had the "high boy" lift from the factory. The truck had the original tires and the split rims on it. In fact, I have the original spare/wheel still riding along where it was since new. Tire still has the mold "nubs" on it. I replaced them with Ford 8 lugs (16"). Cheers.
All 68 and older W 100/200 sit higher than Dseries or 69/71 W100/200 series. Of all the 68 and older W100/200 trucks I have owned or parted they all basically sat the same height.
Maybe someone here has some supporting documentation on the "High Boy" lift you're talking about.
I've never heard of it.
That is a Ford thing.Hobcobble wrote:Maybe someone here has some supporting documentation on the "High Boy" lift you're talking about.
Doesn't look any higher than my stock 68 W200 CS
My stock '68 W200. It has '92 W250 wheels and LT235/85/16 tires.
JohnRe: 1968 W200 production numbers?
Look's the same as my 2 1968 W200' sHobcobble wrote:My stock '68 W200. It has '92 W250 wheels and LT235/85/16 tires.John
Dale,caseman wrote:Look's the same as my 2 1968 W200' sHobcobble wrote:My stock '68 W200. It has '92 W250 wheels and LT235/85/16 tires.John
Do you still have them?
Yes I do =Both have the HD44 Front end's and the HD U Joint's /1 Has 318 / the other I put a 340 in it both parked in the weed's & along the Fence line.
- swptln
- City: East Brookfield
- State: MA
As mentioned the High-Boy thing is Ford, there was no optional lift for the W's. All 61-68 W's will have a block between the spring pack and rear axle only, nothing up front, but it is stock oem. A lot of people refer these truck to the High-Boy era, because of the lifted stance these trucks have and Dodge did lower the W's for 1969-up to lower the center of gravity on the W's.
My 68 with TSL 34x10.50 16's
There are no break down in total number of trucks sold per engine size, only that 1968 model year, 5308 W200's were sold per-Galen's Tag Service, LLC.
The closest you'll come to any production numbers on 68 383 W200 CS's will be to search the registry to see how many are still in existence, other than that, to my knowledge there is no documentation for your question.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
Dennis Barnett
A&P mechanic, General radio Telephone operator
- swptln
- State: MA
Here's a stock 1969 W200 and if you look at the fender opening to the top of the tire, there is a decrease in height, by a couple inches.
Mark D.
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
- 66patrick
- City: Central
- 66patrick
- City: Central
1961-1971 Sweptline Production numbers by model, wheelbase, and 6/8:
www.sweptline.com/hist/prod_info.html
66patrick wrote: ↑Wed Mar 14, 2018 2:12 pm1961-1971 Sweptline Production numbers by model, wheelbase, and 6/8:
Too bad they're is no mention of Canadian built trucks.
- riffraff
- City: Newport Beach
Eh?dodgeboykim wrote: ↑Wed Mar 14, 2018 10:56 pm66patrick wrote: ↑Wed Mar 14, 2018 2:12 pm1961-1971 Sweptline Production numbers by model, wheelbase, and 6/8:
Tom
1969 W100 383/435
1969 W100 383/435
