1970 No Running Lights
DicksDodge
City: San Dimas/CA
Post by DicksDodge »
So,
I have headlights, front running lights, brake lights, turn signals F/R and reverse lights. I do NOT have tail lights or corner marker lights. Any thoughts?
1970 W200 Camper Special 383/4sp.
2018 Ram 2500 Crew Cab LB Cummins
Re: 1970 No Running Lights
DicksDodge wrote:So,
Have you checked bulbs or if power to tail light assemblies when park lights/headlights are on???
marklein
City: Red Deer
Post by marklein »
Bad connection or bad ground. Check for power at the firewall and again at the back. Look at the wiring diagram and see where it is split, then start checking.
MadMC63
City: Rome
Post by MadMC63 »
Don't forget to check the ground straps on either side between the bed and cab.
MadMC63 wrote:Don't forget to check the ground straps on either side between the bed and cab.
If there are sigs, brake and reverse lights, then ground is good!
DicksDodge
City: San Dimas/CA
Thanks for the replies. I forgot to mention I do not have power at the firewall plug. When I turn on the key, I have a keyed power leak (possibly for camper power) but not one for the running lights. By the way, this is after I pulled off the firewall plug. This rules out problems at the rear of the truck. I think the real issue is, my uncle did some splicing over the years he had the truck and though I've had to repair some of them, there may be more that are likely to fail.
On a similar note, how do you get the knob off of the headlight switch? I wanted to pull the switch to make it easier to check power but can't get the knob off.
Knob doesn't come off. The entire shaft, with the knob, comes out of the switch by pressing a release button on the switch. The button is small and somewhat difficult to access. Often they are somewhat jammed and its a fight to get it out. Maybe someone can post a pic, or google is your friend.
MrMopar
City: Lompoc
Post by MrMopar »
Here is the circuit isolated so you can better see it.
Alan
Alan Erland
1967 Plymouth Barracuda
1969 Dodge Polara CHP
1969 Dodge Polara
1970 Dodge Camper Special
www.MrMopar.com
MadMC63
City: Rome
Post by MadMC63 »
If you pull the switch to the on position and look directly behind you will see an orientation tab aligned with the notch in the metal dash. This gives you an idea of how the switch is mounted. Use this knowledge in conjunction with what the switch looks like and it should simplify your removal. The button you can see in the bottom view has a spring.
Switch front.jpg (27.15 KiB) Viewed 944 times
switch bottom.jpg (11.37 KiB) Viewed 944 times
