D600 body panels
- crashresq21
- City: Lincoln
- State: RI
- Location: Manville RI (no seriously, its a village. The day they named the place was a slow day mentally.)
D600 body panels
So as if one 71 wasn't enough, I found this ex railroad company W600 locally. Damn solid mechanically but fenders are razor thin cheese grater quality rust sheets. I can fab up the front drop panel but are there any aftermarket fender panels?Can I use any other quarters? D100 etc?
"Dealing with me is like playing chess with Charlie Manson. 99% of the time you're like 'this guy is on his game', and then there's the one time I shove a pawn up my @#% and dance around"
Re: D600 body panels
To keep it looking proportional you need fenders from a 500/600/700/800 series vehicle. The W500/600 have a larger "lip/flare" than the D series.
100/200 & 300/400 series will I think bolt up but may look puny.
- crashresq21
- City: Lincoln
- State: RI
This is the monster in question. Note the fender is pretty much cheesecloth. Reportedly the front end was custom-built by a separate company (Shuttle Corp.) judging by the narrow width track for railroad work. I was told it has a napco axle and a new process transfer case with PTO. Onboard compressor that is belt driven also.
Normally W600's have Rockwell drivetrain (T-case & axles). Tough looking rig.
That is rad. I bet Kenny Exline could build you what you want. You could probably have him do wheel lips and you'd use smaller fenders. He is a one man shop in PA and a great person.
http://www.exlinecustomauto.com/
Dodge did not make W600 Sweptlines. It is a D600 converted aftermarket to 4x4. The D700 I saw converted with Napco stuff also had p/s.
They did in 72 and 73.PwrWgnDrvr wrote:Dodge did not make W600 Sweptlines.
Yep the W500 designation was "retired" after 1971.
I'd like to see more pictures of that rig.
- City: St. Johnsville
- State: NY
PM sent.
