Fuse box
Fuse box
Does any one have a good picture of a fuse box or wiring diagram. 1967 dodge power wagon LA 318 I'm trying to fine out the correct amp for each circuit. I have missed match fuses also does any one know how the RPM Gauge is wired does it do to the coil if not where does it gain its signal
Re: Fuse box
Tachometer (RPM gauge) usually has 4 wires. 1 for power, 1 ground, 1 for lighting & the signal wire which usually goes to the minus(-) side of the coil.
- pwadventurer
Re: Fuse box
From my 69-71 service manual,Slyfoot wrote:Does any one have a good picture of a fuse box or wiring diagram. 1967 dodge power wagon LA 318 I'm trying to fine out the correct amp for each circuit. I have missed match fuses
A.C., Brake sentinel, camper electrical feed, cigar lighter, directional signal, dome lamp, EM flasher, heater, horn, parking lamps, stop lamps, and tail lamps all 20 amps. Back up lamps and radio 6 amps. Instrument lamps 2 amps.
Edit to add: 67service manual, from Jims68 post, viewtopic.php?f=21&t=40372
Voltage regulator 6 amps, horn 30, turn signal 15, tail/stop/brake/dome 15, 4-way flasher/ cigar 15, instrument 2, radio 6, heater 20.
68 models: accessory xx, Horn 30, turn signal 15, tail/stop/brake/dome 20,4-way flasher /cigar 20, instrument 2, radio 6, heater 20.
- pwadventurer
Re: Fuse box
not listed above in your 67 fuse block, is the voltage regulator fuse. Maybe some one can check their fuse block.
Edit to add photo;
Edit to add photo;
