Need a Knuckle
- powerwagonpaul
- City: Las Vegas Nevada
Need a Knuckle
anyone parting out a 69 and later power wagon? i need a steering knuckle for my 69 w200, drivers side. also need the knuckle arm that ataches on top and goes to the drag link, with shims. the bearing (king) pin broke off and all the studs striped and pulled out.
- powerwagon54
- City: Washougal
Re: Need a Knuckle
pm sent
- powerwagonpaul
Re: Need a Knuckle
powerwagon54 has the knuckle! i would prefer to get both pieces from the same truck, i possible. if not, anyone have the steering arm to go with pw54's knuckle?
Re: Need a Knuckle
Its been awhile but did you find the last part you needed.
- gotAgreenMachine
- City: Oakland
Re: Need a Knuckle
I'm looking for a nuckle set also I happened to break the right passenger side housing anyone have ideas on a power wagon grave yard in the west coast not her CA?
Re: Need a Knuckle
gotAgreenMachine wrote:I'm looking for a nuckle set also I happened to break the right passenger side housing anyone have ideas on a power wagon grave yard in the west coast not her CA?
I have large and small knuckles. P M me for what you need exactly. I should have it.
Re: Need a Knuckle
Do you have a closed knuckle for a 1959 powerwagon? Dana 44 axle.
- powerwagon54
- City: Washougal
Re: Need a Knuckle
I may have it.
Re: Need a Knuckle
If PW 54 does not have one, I might.
Re: Need a Knuckle
I have a complete Dana 44 HD, 8 lug, closed knuckle, 4.10, out of a 1963 W100 (same as W200) up for grabs. Located in Santa Fe, NM.
