Working on the brakes of the '61 D100 this week and I ran across this bit of farmer fix-it:
The wood has to have been there for at least 30 years and probably more.
So...what do you think?
Re: So...what do you think?
Pull it off and see whats up.
Yeah, pull it off, but save the wood..... you may have to put it back on! Let's see some Pics after you see what is going on please.
- slick
- City: Tucson/AZ
- State: AZ
What's it fixing?
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
Is there a S.E.R.T. code for that?
Hi i just moved to meridian last Dec. Iam by victory gardens.
1965 D200 Crew 5.9L MPFI/A518
My guess is that the U bolts are oversized, and rather than look for ones that fit they used the wood to make up the difference.
I finally found out what was up. I was at the muffler shop getting the exhaust system redone. The guys there say that the truck used to have helper springs on it. That's a leftover U bolt that was probably rusted on. Instead of cutting it off, grandpa just stuffed a shim in there so it wouldn't rattle around. It's gone now.
Glad the mystery is solved!
