67 POWER WAGON SHORT WIDE-PROGRESS
- City: belleville,il.
Re: 67 POWER WAGON SHORT WIDE-PROGRESS
Those inserts are available from restoration specialties
Well Mikebell, I looked in my stash of bolts & they didn't turn up. I will have my dad look over the fender that I removed & see if its there.
How many inserts are there per fender? Even though I removed the one fender myself I wasn't particularly paying attention to how many different bolts/nuts etc were holding it on. And it was almost a year ago when I removed it.
The passenger's side fender is still on the truck. I could pull you an insert from that one next time I'm down there.
Maybe try Auveco for the captive nuts.
Bucky, Don't worry about it . Thanks for your effort. I will find something. Thanks again.
Adam, I will check on those. Thank you
good luck with your search. I should have paid better attention when I removed that one fender, but since I don't live there I'm usually pressed for time while there.mikebell wrote:Bucky, Don't worry about it . Thanks for your effort. I will find something. Thanks again.
