high oil pressure, blowing oil out dip stick tube.
Re: high oil pressure, blowing oil out dip stick tube.
i have a snap on double gauge. it has the inlet gauge so i can monitor how much air i put in and then the second gauge will read pressure drop.
1966 Dodge D100 Custom SC SWB
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
if im speaking jiberish let me know and ill try to re word it.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
OK sounds like you used the correct tools. I looked up a few threads on oil blowing out the dipstick and all I find is blow by but that doesn't seem like your issue if there is no leak down.Jake66 wrote:i have a snap on double gauge. it has the inlet gauge so i can monitor how much air i put in and then the second gauge will read pressure drop.
1965 D200 Crew 5.9L MPFI/A518
The only thing I can chalk it up to is not having a pcv valve. I have two oil breather caps but who knows.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
- City: Rio Linda
If you have both breathers teeing into the vacuum port of the carb, you need an air inlet somewhere (PVC) to draw the vapors though the block. Only run vacuum to one breather and leave the other breather unhooked so engine vapors can flow into the engine. The arrows on the diagram represent the flow of vapors though an engine. White smoke shows a leak of antifreeze into a cylinder (head gasket, cracked or warped head), what did the plugs look like when you pulled them? Do a strait compression test the way "kurt" suggested as the 170 in/mg is high. Did you seal the 4 engine corners exhaust manifold studs (or bolts) as they run into the water jacket on 318s and 340s, think 360s are the same and could be leaking into the exhaust manifold. Last, but not least, get a Factory Service Manual.Jake66 wrote:The only thing I can chalk it up to is not having a pcv valve. I have two oil breather caps but who knows. :thinking
My plum were all clean and uniformed. No discoloration. Just looks like a clean normal use plug. Ill hook one up to my air cleaner and the other to the back of the carb. See what that does. Ive got a factory manual, for both 66 and for the 77 that my motor is out of.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
alright guys, i got it all figured out. i ran new hose, longer this time from my pcv valve to the back of the carb. then, used a cleaned oil breather cap and ran new longer hose to the air cleaner. free of any kinks, extreme bends ect.. fired her and hauled off down the freeway and i had no oil spray or anything inside the engine bay. clean as a whistle. no more shooting in the dark thanks for all the input, i timed my engine and adjusted it accordingly and the slight white smoke is now gone. and i get roughly 14 miles per gallon not the greatest but hey it will do.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Neither my 2004 Astro nor my wife's 2010 Grand Caravan get better than 14mpg in town.
My only guess as to why it does as good as it does is because it weighs so little without the bed on it and having a transmission that forces me to accelerate slowly. Also a two barrel carb helps.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
I Never would have thought just the pcv would cause that. Older cars like my 62 falcon just had a breather hose exiting under the car.
I had 1966 belvedere with a poly 727 and 273s that got 21mpg all day long.
yeah i was baffled that it could be something so simple. but yeah im happy with my fuel economy, i know some guys in my area that dont get that MPG out of there new trucks.kurt wrote:I Never would have thought just the pcv would cause that. Older cars like my 62 falcon just had a breather hose exiting under the car.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
kurt, you seem like someone who would be able to answer this for me. i have a stock dana 70 LD on my truck, 10 bolt. how much gear oil do you think it would take to fill it up? those squeeze bottles is what im referring to. and what weight would you use?
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
Jake66 wrote:kurt, you seem like someone who would be able to answer this for me. i have a stock dana 70 LD on my truck, 10 bolt. how much gear oil do you think it would take to fill it up? those squeeze bottles is what im referring to. and what weight would you use?
Actually I have no idea. This pic is from a 1968 service manual it says 6 pints. I googled dana 70 and the newer ones take 7 pints.
- sweatybetty
- City: s.w.
do you have something against "afros"?Jake66 wrote: afro engineering
nothing at all, jerry rigging is more in league with the way i do things. i don't mean to stir up a hornets nest. sorry for the comment.sweatybetty wrote:do you have something against "afros"?Jake66 wrote: afro engineering
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
- City: Rio Linda
Something against "jerry" rigging?.... old school derogatory term for German people. Can't win for losing now days.....lol...Jake66 wrote:nothing at all, jerry rigging is more in league with the way i do things. i don't mean to stir up a hornets nest. sorry for the comment.sweatybetty wrote:do you have something against "afros"?Jake66 wrote: :joker afro engineering
nothing at all, jerry rigging is more in league with the way i do things. i don't mean to stir up a hornets nest. sorry for the comment.[/quote]
right, oh well, at least in this instance im referring to myself. i dont know, seems now days you say one thing and its interpreted in so many different ways that its impossible to avoid making people un happy. old schools better than new school
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
- City: Rio Linda
:lol: right, oh well, at least in this instance im referring to myself. i dont know, seems now days you say one thing and its interpreted in so many different ways that its impossible to avoid making people un happy. old schools better than new school :usa[/quote]
The dumbing down of America....it's inevitable, looks who's in "charge".
I am right there with you, there were better people that could have been put into office. They would have helped bring the economy back and would actually have a foreign policy. Whatever happened to "we will not negotiate with terrorists" ???????????? I am red, white and blue died true in the wool, come from a military family some might call me a radical extremist. I prefer flat plain and simple, I am american.
Bermuda Turquoise
And
White
Bermuda Turquoise
And
White
- HEtkind
- City: Johnson City, Tennessee
My guess is that bottom ring, the compression ring is bad. Try a leakdown test and see if you air out the breather.
Howard
Howard
Howard
62 Dodge D100 Town Wagon
62 Dodge M-37
68 Dodge D100 Utiline
2007 Dodge Ram 1500ST
62 Dodge M-37
