My 1969 Crew Cab with PICTURES
Hello my name is Max and Ross is my dad, I am 14 years old and I am making my first pickup. So let me tell the whole story. First my dad said that my grandpa had an old 1964 D-100 in his shed that he would give me for free. We were gonna put 3/4 ton 4x4 runnig gear under it. After getting to the point of taking the cab off, I found a early 1965 crew cab sweptline D-200 adout a mile down the road at my other grandpas house. We started dealing with them and go the pickup. I was gonna replace the sweptline bed with the utiline off the D-100. We thought about using newer running gear instead of the 1967 stuff we got from Rob(Powerwagoncrazy). I found a 1985 W-350 but it only had a dana 44 front axle .The body was trash so we took anything that my have been usable or sellable(axles,hitch,brake booster,cab mount pucks,proportion valve,Married unit NP435/Np208) the rest we scrapted because it was beeeaaattt.After taking the cab off the crew I noticed the cowls were rusted bad, but the floors were amazing. It makes sence because the pickup sat facing uphill under a tree. The Frame was so nice. I found and bought a 1989 dana 60 front and a 1989 dana 70 rear. Searching for a crew cab pickup, I found a 1968 Crew cab in Idaho Falls, Idaho we got lots of pics and decided to go buy the pickup. the cab was in such nice shape but the front floors were gone,no problem, the cowls still had paint in them. Just one problem, The fame was cut right in fromt of the transfer case mount holes and had a 1989 Frame welded to the front , his plan was to put a cummins in this pickup but he could never get the front clip front the guy he bought it from(he later got it)and he lost interest and put the cummins in a 1974 Ford 3/4 ton 4x4 Highboy.It was a long ride. After getting home I just found out about all the changes in 1969 and found out this is a 1969 .We were going to try to modify the cab to fit the old dash. I decide to change plans and to make a 1969 pickup by changing the frame(Its a lot of work)and using a 1970 Grill(I am still trying to find a strait one). I got a lot of the later frame peices From wildcat auto wrecking(they have a lot of parts pickups, Thats the place to find any mopar parts). I just still need the later motor mounts that are riveted into the frame. Luckily the half frame had been cut long enough so that we could get measurements for the transfer case holes. I have got all of the cross members out except for one to keep the frame lined up, I painted the boxing the frame pieces, tranny crossmember, and brackets. I installed the boxing the frame pieces and am at the stage of putting in the transfer case crossmember because i have the measurements between that and the tranny crossmember and that is the one I can get measurements for without the motor mounts. I will Keep this update with how far I am. If any of you did some dealing with Ross(buying stuff) You are actualy dealing with me I just use my dads E-mail and write "Thanks Ross" at the end of all the messages, but my dad also does that too.
Thanks Max
Thanks Max
Re: My 1969 Crew Cab
More Pictures
1969 Dodge Crew Cab
- dietzdiggler
- City: union
- State: SC
Can't wait to see the pics! Its great to see the swepty's getting some appreciation from the younger generation. Hope we're able to help you out here, Good Luck!
2 Corinthians 7:10 ---> Romans 10:9
1965 Dodge Polara 383
1963 D-100 step side 5.2 magnum
1967 Plymouth Belvedere II 383
1962 Plymouth Belvedere station wagon 361
- BigBlockDodge
- City: Wingina
- State: VA
If you have any types of technical questions, this is the site to go to. There are a LOT of really smart people on here! It Sounds like you have one heck of a fun project going on! I would love to see some pictures too! I can totally relate to what you are doing because I have a 69 w100 that my Dad gave to me when I got my learners permit (I'm 19 now). But my Dad got the truck when I was about 11 and I was always out in the garage helping him work on it!
Sam
69 Dodge W100 SWB. 383 4bbl, 4-speed
- SomethingCrazy68
- City: Butler, PA
Try opening your pictures in "Paint" and resizing them in order to post. You can decrease their size by percentages. good luck.
"Outside of a dog a book is a man's best friend. Inside of a dog its too dark to read."-Groucho Marx
"I HAVE COME HERE TO CHEW BUBBLEGUM AND KICK @#%, ...AND I'M ALL OUT OF BUBBLEGUM!" -Roddy Piper in "They Live"
1968 D100-318 Auto
2005 Grand Caravan SXT
2003 Triumph Speedmaster
1968 D100-318 Auto
- jimmy
- City: Spokane
Sounds like you have a great start. As mentioned the guys here are great help.
This is a link to my truck 69' crew cab build. Hope it helps in someway. I used 92' 3/4 ton D60front & D70rear axles, 99' Quad cab seats, 78-79 4x4 ford ps box, suberban fuel tank, and a 70' grill. this is just how I did it, feel free to look around my page. I will take a minute to open.
Post some pictures when you have a chance.
http://jims69dodgeproject.blogspot.com/ ... chive.html
Jimmy
65' Satellite 383 4spd
65' Satellite 440 727
69 Power Wagon Crew Cab
Re: My 1969 Crew Cab with PICTURES
Some more and are those overload leaf springs stock.
1969 Dodge Crew Cab
Max,
Do you still need the newer frame motor mounts?
Im not sure about the leafs, Mine has them too.
- moparbob71
- City: 21797
Great to see this much interest in the trucks.Looks like you live in Swept country.
PS- I want your shop
Good looking truck & shop.
Hope ya got my email about the emblems.
Does that truck in the back of the shop look sort of like this one?
- Attachments
73 CJ5 304V-8 Metal Cab
Welcome to the site Max. Thirteen years old huh?.... good to see a guy getting
an early start! There are many folks here willing to help you and your dad
get your project up and running. Looks like you have plenty of elbow
room in that shop too.
- jimmy
- City: Spokane
Great Work. Most of us would kill for a shop and equipment like that. Put them to good use, as it looks like you already are.
Guy's we might be talking to the next Chip Foose! I started wrenching real young also, I wouldn't trade my education for the world.
Keep us up dated.
Keep us up dated.
Jimmy
- surfnuke9
- City: Churchton
That is one sweet shop to work in. Makes my 24X26 garage look like a walk in closet.
Tim
- slick
- City: Tucson/AZ
- State: AZ
nice trucks. That is a hell of a garage...My 1 car carport is getting old
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
Thats My Dad's 1946 Dodge 1/2 ton 2x4 With a 302 Ford with a C4 Automatic Tranny and was a frame off restoration. The Shop is 60x75 feet.MOPAT wrote:Good looking truck & shop.
1969 Dodge Crew Cab
- dietzdiggler
- City: union
- State: SC
I'm 35 and still working under an oak tree. Lord willing though, I hope to have a shop soon.slick wrote:nice trucks. That is a hell of a garage...My 1 car carport is getting old
I am dealing with a guy right now for the mounts.Maxdigdoug wrote:Max,
1969 Dodge Crew Cab
- wideblock
- City: las cruces nm
- State: NM
dietzdiggler wrote:I'm 35 and still working under an oak tree. Lord willing though, I hope to have a shop soon.slick wrote:nice trucks. That is a hell of a garage...My 1 car carport is getting old
at least you got a tree. im dealing with a gravel driveway and lots of sunshine. concrete and a shade tree would be a huge upgrade.
Trey
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
