parts interchange
parts interchange
Postby cheapshot » Fri Nov 24, 2006 8:14 pm
what years will the body parts interchange for a d100. i need a new hood and bumper for my 70 model, but the bone yard only has one d100 and i think it is an early 60s. im not real familiar with these trucks, i just bought my first sweptline last week, but the only thing that looks real different is the hood, and even it looks like it would fit.
cheapshot
Postby digdoug » Fri Nov 24, 2006 11:05 pm
69-71. :Thumbsup :welcome
digdoug
Postby mopardwh » Fri Nov 24, 2006 11:21 pm
digdoug wrote:69-71. :Thumbsup :welcome
Yeah, as far as looks it's a 69-71, but any year 61-71 should fit. In fact, from the cab forward should be interchangable; cab, doors, fenders, rad support+grille+headlights. As far as beds, I think 61-65.5 have different lengths than 65.5-71. And I know the tailgates are different. :Thumbsup :welcome
Postby Jeffc » Sat Nov 25, 2006 3:37 am
69 to 71 are direct swaps on most things.
There will be differaces in earler years,
just depends on what you what to do or go...
Doors > compleat 68 to 71 (67 has diff inside)
61 to 66
Hood 69 to 71, 68 one year, 61 to 67
also:
there are trim diff on hole placement
if hood had trim or was trim delete..
Fender front> all the same stamp but will
have diffeant holes for trim/lights
Jeffc
Postby OregonDodgeboy » Sat Nov 25, 2006 5:04 am
Jeffc wrote:Doors > (67 has diff inside),...
What exactly was different?
Jeffc wrote:Hood... 68 one year
I thought the hood for 68 was the same as the previous years.
Inquiring minds want to know. :lol:
Jeff Easterbrook
67 W200 440/4-sp. Resting
76 IH Scout II
81 MB 240D
OregonDodgeboy
City: Nampa, Idaho
Postby cowboy » Sat Nov 25, 2006 9:21 am
the 68 hood will fit on the 69-71 , but not back aye years with out some cutting , the top look's like the older's ones but has the stright edge across the front lip like the 69-71 , not bent up for the single head light pie plate style
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
cowboy
Postby Hemikuda71 » Sat Nov 25, 2006 12:03 pm
Yeah thats true. You can put it on earlier years but it doesn't fit right as you can see by the photo of my '64 with a '68 hood. Hey Dave, the orange van in the background has a good small block 727 in it. You still need'n one? Let me know.
R/T
'61 D-100 Utiline (Lil Red)
'62 D-100 SWB
'64 D-200 LWB CSS 1 of 2 known 3/4 ton CSS's
'68 A-100 Pick Up
'72 Challenger
'72 Demon
'78 "Lil Red Express"
Hemikuda71
City: Oklahoma City
Postby Jeffc » Sat Nov 25, 2006 1:39 pm
67 doors come in 2 types, one just the same as
all early years with the pull handles frig handles
(granted you will not see many, but they are out there)....
the other 67 has the pushbutton outside
handle (and will swap right in to the 68 to
71) but the inside will have the older type
pull door handle and steel cover.
Looks the same till you try to put it on a 67,
because of the cutouts for the headlight are not
there, their strait across on the bottem front
edge instead of having a rised piece on each side
for the headlight doors (i.e. 4 HT panel 61 to 65.5, pie pan 65.5 to 67)
Jeffc
Postby cheapshot » Sat Nov 25, 2006 5:14 pm
so, as far as functionality, the mid 60s hood should bolt up and work with a 70 model front end? the grill on the truck i am talking about looks nothing like the grill pictured on the snow covered truck above, it looks almost identical to the grill on my 70. any ideas as to what year it might be? and thanks for the input, you guys have been great around here!
cheapshot
Postby cowboy » Sat Nov 25, 2006 8:15 pm
cheepshot, If the Tsignals are just inside of the headlight's & run frim top to bottom it's a 68-69 grill , 70-71 grille's look different , the T signels are just inside the headlight's & to the bottom , with plactic insert's , go to the pic' section & look under scott& R/T trade those are the 70-71 grille's
:usa
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
cowboy
Return to **GENERAL TECHNICAL HELP**
Who is online
Users browsing this forum: No registered users and 7 guests
