Hello
I'm looking replace the yokes on my 1968 w200 from the obsolete detroit 5381 ujoints to the spicer 1410. I got the correct spicer pn for the rear axle but need the numbers for the following:
1) 201 transfer case
2) dana front 44 coarse spline
3) Np435 coarse splines
I'm aware I can get the tcase yokes from torqueking, but they don't provide the spicer pn and hoping to get them cheaper
Appreciate any help
Thank you
MikeM
Spicer yoke PNs for drivetrain
- PowerMan
- City: Auburn
Re: Spicer yoke PNs for drivetrain
I have been able to get a 1350 series yoke for the NP201. I don't believe 1410 yokes are available for the NP201.
I've used this website to get a better idea on availability of various yokes:
https://www.northerndrivetrain.com/cate ... lined.html
Thank you for the reply. Using a spicer catalog I think I got the correct pn figured out for the tcase. I'm going to order one and see if it works.
- PowerMan
- City: Auburn
Interested to hear what size yoke you found and part number as I may be replacing a few yokes in the future.
I think the Tcase yoke PN is 3-4-2271-1. It is a 1.375-10 spline dia. yoke hub that seal rides on is 2 125 and the spline length is 2.00. This PN matches up with another discussion I found doing a search on this forum. I measured a spare yoke I have for my M37, that matched these dims, but I need to pull off the yoke from my PW to double check
Rear dana 60 spicer PN I've been told is 3-4-4451-1X
For dana 44 front, I couldn't find one.
Thanks
MikeM
Thanks
MikeM
