People are adding transmission coolers to their air compressor as a water condenser and rig it up with 3/8 id line. I have a 9hp and will probably be ably to use 5/8 line, but will I be able to keep it functional if I want to sandblast, or am I'm concerned about nothing?
*we still doing 3rd party websites to post pictures?
Air compressor Cooler
- reallylongnickname
- City: Ottawa, Ontario
- martincom
- City: Five Points
Re: Air compressor Cooler
In my opinion, you'll lose far too much volume. Especially for items that require a lot of volume, such as sandblasting or large impacts.
When I did the shop in the home we just sold, I had a 5hp compressor. At the time, it was the largest they offered for single phase. I utilized a 2" galvanized pipe as the main trunk line. It wasn't so much for the volume, though that was a side benefit, but the heat dissipation. My air compressor was at the other end of the shop from where I did the most work, to minimize the noise. So I had a fairly long trunk line.
All my taps came off the top of the 2" trunk line. All the lines, except those ran above the bench or horizontally along the wall, were sloped to drain. I placed a drain stub/valve at the bottom of every vertical wall drop.
I've seen other fellows install a second tank between the compressor and the trunk line. This provided heat dissipation as well as additional storage capacity.
- martincom
- City: Five Points
Photobucket started charging a fee, I believe, and also may have a time limit. I utilize Microsoft Office Picture Manager to re-size mine. It is pretty simple. You just open the photo with it, click "Edit Pictures" in the top toolbar, then click "Resize" in the right frame toolbar that opened. Next, select the "percentage" resize bullet. Choose a percentage that yields a save photo that is smaller than 240kb. Save the photo with a new name. If you just click save or click the save prompt when exiting, it will overwrite your original photo.reallylongnickname wrote: ↑Sat Sep 03, 2022 12:34 pm*we still doing 3rd party websites to post pictures?
