I was driving down the highway at about 60 mph and my 1968 Crewcab W200 locked up. I was able to get flatbed towed home and discovered that me transfer case bearing was the culprit. I ground the bearing off, but is too much work to grind the inner bearing part on the shaft. Does anyone have a NP201 transfer case around that they would be willing to part with.
Thanks in advance. Steve in Washington State.
Need a NP201 transfer case
Steve
North Bend, WA
68 W200 Crewcab
45 Dodge Dump Truck
66 Ocelot Corvair powered Dune Buggy
North Bend, WA
68 W200 Crewcab
45 Dodge Dump Truck
- City: Binghamton
- State: NY
Re: Need a NP201 transfer case
What bearing was it that went south? When I got my 65 it was the rear output bearing on the 201 transfer.
My solution was to update to a 205 transfer, much the same as dodge did for these trucks.
I did however make it very hard to find a PTO to power the winch.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Have you asked over on the power wagon sites? Those guys stock up on parts like they were cans of soup.
- City: Sandpoint
- State: ID
I sent a private message to you with contact information regarding the NP 201.
