Sound deadening
Sound deadening
Im getting my floor pans replaced soon, fixing the rust. While everything is out of the cab I want to try to make my cab quiter. Has anyone done this? Dynomat any good? If possible I would like to be able to take work calls while driving. Thanks!
Re: Sound deadening
Carpet helps a lot.
Re: Sound deadening
Underbody coating also helps.
- City: Binghamton
- State: NY
Re: Sound deadening
A nice thick headliner will help. Also less aggressive tires makes a difference.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Sound deadening
Factory offered sound deadening insulation panels that attached to the firewall above the carpet up to the heater and wiring and also on the kneewalls.
Re: Sound deadening
New pins to hold that fiberboard/fiberglass insulation can be found on ebay.PwrWgnDrvr wrote: ↑Fri Feb 18, 2022 3:29 pmFactory offered sound deadening insulation panels that attached to the firewall above the carpet up to the heater and wiring and also on the kneewalls.
https://www.ebay.com/itm/254838516713?c ... a5db1a91e3
- martincom
- City: Five Points
Re: Sound deadening
I utilized Hush Mat, that I sourced from Summit Racing. It also slows thermal conduction as well as a moisture barrier from melting snow that soaks carpet and the sound deadening pad attached to bottom of it and the rubber mat. I utilized it for the floor boards, rear cab wall, the inside of the door skins, and the roof. It really made a difference. The doors have a more solid feel/sound when closing. I have photos of the installation, but I'm traveling now and I don't have access to my server. I utilized foil HVAC tape to seal the Hush Mat joints.
I wouldn't bother with the fiberglass backed fiber board for the firewall. They are real flimsy and not forgiving. I ran the Hush Mat all the way up. I sourced the Auto Direct carpet from Rock Auto. It is also cut to go to the top of where the fiberglass backed fiber board would end. So I ran it all the way up and utilized large head christmas tree fasteners to secure the carpet in the fiber board holes.
Re: Sound deadening
True indeed! But if the poster or someone searching the topic is planning a "restoration" the original material would be required.
Good to facilitate both.
Re: Sound deadening
Thanks everyone! Im going to order some Hush Mat and new carpet. Im also going to look into undercoating.
Re: Sound deadening
does anyone make new firewall pads?PwrWgnDrvr wrote: ↑Fri Feb 18, 2022 3:29 pmFactory offered sound deadening insulation panels that attached to the firewall above the carpet up to the heater and wiring and also on the kneewalls.
- martincom
- City: Five Points
Re: Sound deadening
Robin is taking pre-orders. His web page is blocked from the site. It is easy, followed by, street, followed by llc and then .com There is dash between easy and street.
- City: Lawton
Re: Sound deadening
Good information as my "68 D100 longbed is going to go through the same deal as well as mysteriously turn into a factory shortbed in the process lol.
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
