Turn signal
tgall595
City: Winnemucca
Turn signal
Post by tgall595 »
Any tips for disassembly of steering wheel to replace turn signal switch/repair turn signal
67step100
City: Niagara, ON
Re: Turn signal
Post by 67step100 »
You don't specify a year and model so don't know if they are all the same. For my '69 100 I remove the horn ring, disconnect the horn wire and then the ring that is screwed to the wheel hub (3 screws). Then remove the steering wheel (you'll need a wheel puller). Then you should see the turn signal switch. It is held down with a single screw in the centre that also holds the indicator stalk in place. Once the screw is removed you can pry up the switch. I take a picture as I remove each item so I know how they were oriented when I put it back together. It's a good idea when you disconnect all the wires under the dash you tie a string to one of them when you pull it through. Then you have something to pull the new wires back down the steering wheel column.
Where did you source a signal switch? I am going to have to replace mine as well and have been looking at the typical suppliers (rockauto) and wonder if they are any good.
martincom
City: Five Points
Re: Turn signal
Post by martincom »
67step100,
I purchased one of the NOS switches bluegenes referenced in his thread:
viewtopic.php?f=21&t=43833
Presently, I have an 18 month old China repop in the '71 D100. It took a fair amount of fiddling to make it function correctly when installed. Now, it is starting to be troublesome about latching into the right turn detent. So I maybe installing the above referenced replacement in the near future. I see there are still some available from that Ebay seller.
67step100
City: Niagara, ON
Re: Turn signal
Post by 67step100 »
martincom wrote:
Mon Sep 27, 2021 6:17 am
67step100,
Will that switch work for a D100? It says D300, 400 and 500.
67step100
City: Niagara, ON
Re: Turn signal
Post by 67step100 »
67step100,
So I am confused. Attached is a pic of my switch, which is pretty much all plastic. The switch on ebay is primarily pot metal by the looks of it. Is my existing switch a repop and will the metal one work in my situation?
Re: Turn signal
67step100 wrote:
Mon Sep 27, 2021 10:36 am
67step100,
68 and older column is different than 69 to 71
67step100
City: Niagara, ON
Re: Turn signal
Post by 67step100 »
dodgeboykim wrote:
Mon Sep 27, 2021 12:30 pm
Mine is a '69 column.
martincom
City: Five Points
Re: Turn signal
Post by martincom »
I was/am relying on the information shared by other members in the thread I referenced. They state it'll fit and work. However, the wire length may need to be altered and possibly the harness connector is different.
Plastic was a new technology in the '60s and slowly began to work its way into vehicle production. As such, I wouldn't at all be surprised if earlier switches had a pot metal housing and later years were plastic, but yet interchangeable. My '69 Daytona Chargers lower dash cover is vinyl covered pad. My '70 Charger R/T lower dash cover is plastic. The dashes are essentially identical other than that and the column mounted ignition & emergency flasher switch in '70, as well.
ozzie
City: colorado springs
Re: Turn signal
Post by ozzie »
looking at the pins on the other end, they look correct for 69, and 71. 68's had bullet connectors. so it might work if it mounts alright in the top part of the column.
ozzie
martincom
City: Five Points
Re: Turn signal
Post by martincom »
So what did you finally do? My existing China re-pop is acting up after 10 months of service. It doesn't always return fully, when cancelled, from a right hand turn. Just enough that both of the rear lamps flash, as if the emergency flasher was on.
I have the die cast ebay switch and was wondering if that was the route you took and if you encountered any issues?
67step100
City: Niagara, ON
Re: Turn signal
Post by 67step100 »
martincom wrote:
Mon Oct 04, 2021 3:31 pm
I ended up just getting the one from rockauto. I didn't want to spend $130US to find out it wasn't going to fit. I have enough new parts already I can't use and will need to resell (not this vehicle). It just dropped into place. I had to replace the ends to bullet connectors but everything is working, including the self cancelling. It ended up being easier to replace than I had anticipated. Some of the wire colours are different but easy enough to sort out if you have your original to compare. I'm hoping it lasts more than a year.
martincom
City: Five Points
Re: Turn signal
Post by martincom »
67step100 wrote:
Mon Oct 04, 2021 6:51 pm
You made a wise decision. The die cast switch does not fit. I ordered a replacement from Rock Auto, also.
