fuel tank
sovereignroom
City: san leandro
fuel tank
Post by sovereignroom »
does anyone have a step by step process on how to remove the fuel tank on a 1966 dodge d100
Re: fuel tank
Its easy. Easier if you remove the seat as well as the seat back. Remove bolts top and bottom, disconnect fuel line, sender wire and fill pipe. Drag tank out. Try to have it as empty as possible to reduce weight and spills.
martincom
City: Five Points
Re: fuel tank
Post by martincom »
Pretty much what PwrWgnDrvr stated. The filler neck grommets are likely near hard as a rock from age. So warming them with a heat gun will make them pliable and easier to extract the filler neck.
This is a good time to replace the fuel line and wiring grommets, that pass through the floor pan. I utilize rubber roof mat for the bottom and back wall tank pads. It is far more durable than the OEM felt pad. The price is usually right---free, from a roofer's scrap pile or dumpster.
Re: fuel tank
Good idea to warm the fill pipe grommet if it doesn't slide out.
Pre 70 tanks don't use the grommet. The tank has a nipple with a rubber hose coupling clamped to it and the fill pipe.
sovereignroom
City: san leandro
Re: fuel tank
Cool thanks guys, I've already removed the seat and starting unscrewing some bolts for it , need to get some tools now !
azdodge07
City: Phoenix/AZ
Re: fuel tank
Post by azdodge07 »
Any tips on cleaning out the fuel tank once removed? I have minimal tools, fuel is not cutting through the sludge. I thought of taking it someplace ( may still, but $250). I've been told the "Seafoam" product is good, but the whole tank is rusted and just awful looking inside.
my5thmopar
City: Columbia
Re: fuel tank
Post by my5thmopar »
Search is your friend. See my post here. viewtopic.php?f=19&t=40848&p=291114&hilit=Chain#p291114
67step100
City: Niagara, ON
Re: fuel tank
Post by 67step100 »
azdodge07 wrote:
Tue Oct 05, 2021 1:28 pm
Keep in mind that if you have a significant amount of rust inside the tank your tank wall thickness has been compromised. Once you clean out all the rust you may have spots where the metal is only paper thin. You might be better off looking for a good used tank or a new one. Yes, costly but you will never have to worry about it again, or particles of rust in the future clogging up your fuel filters. Just my 2c.
martincom
City: Five Points
Re: fuel tank
Post by martincom »
Ditto 67step100's comments. Also, you'll never get the tank 100% free of rust. Rust particles will still work loose over time and you'll have trouble in the remainder of the fuel system with plugged pickup strainer, plugged filters and potentially plugged jets/passages in the carb.
Finding a good donor tank can be difficult. Perhaps you've looked into an outfit that does fuel tank re-conditioning. I don't have any experience with them, but considering the number of locations and lifetime warranty, I'm thinking they have a good product:
https://www.gastankrenu.com/
