new parts truck 65 d100 ??
so i have 2 67 d100s
and came across this d100 for parts ,
guy says its a 63 but it has the same grill and bed as the 67 but different doors and dash
also has single master cylinder
haven't gotten the title yet
thinking 65 ?
the only thing i want is the nose cab has normal rust
doors wont work ? ... would love to change the dash (does it bolt in ??)
thanks paul
thinking 65 ?
thanks paul
Re: new parts truck 65 d100 ??
63 has 4 headlights, mid yr 65 thru 71 have 2.
mid yr 65 thru 66 have early doors (61-66), 67 are one yr only doors, but will fit thru 71.
Dash is the same 61 thru 68.
67 cab is a different stamping at the door strike than earlier cabs, which are all the same. Early doors will fit later cabs, but the strike area requires modification and vice-versa
great thanks
whats is different about 67 doors
my ulitline is getting a 63 style nose disk brakes other then that slant 6 ,3 on the tree
the other 67 might do frame swap /or independent front end swap and a 4.7 auto
i do like the clean look of the 65 dash and like the door handles of the 65 but dont think worth the trouble to swap (and the sweptline has a cool looking patina
thanks again ,paul
thanks again ,paul
67 doors have later style handles (and latches) on the outside, early style handles on the inside.
- City: Niagara, ON
Can you post some pictures?
The dash should be the same. There might be some things in different locations, but the overall dash is the same.
i have no idea how to compress my files to fit
when i figure it out i'll try and post some picks
ok great i'll post some pics of my junks
thanks paul
thanks paul
this is the shop truck
got if off ebay with my other 67
i already got 1/3 of the garbage out (can only throw so much in my dumpster each week)
other 67 long bed fenders got painted for shop truck, and i beam was redone /springs and shackles in it now
now that i know how to post picks i'll make a build thread
starting to warm up so hope to drive this spring
