Antenna
Antenna
General antenna question that someone may have ran into or has an answer to. Doing body work on my 68 W100 and found antenna holes on both the drivers and passengers side cab cowl? Does anyone know if Dodge had a special option for two antennas? I believe the original antenna port was on the drivers side. Thinking previous owner may have added antenna to passenger side? But..... before a weld up the hole I wanted to make sure this was not a factory option? Thoughts, ideas, confirmation appreciated. Thanks.
1968 W100
1967 Plymouth Barracuda
Re: Antenna
My 66 had the Factory Radio with antenna on the right side.
Re: Antenna
Never on the left side from the factory.
