Turn Signal Switches - 61-64 parts
jonw500
City: Hanna
State: WY
Post by jonw500 »
In the process of building up a vehicle with donor parts one finds interesting things. So between the 1961 D500 & 1964 D200 there's a few differences between the steering column parts and such, here's the short listing:
1961 D500 - PN 1939389 (says metal and was used thru 1969)
  • shaft is 2 different diameters 0.875 on the bottom and steps down to 0.750 on the top bearing area
  • turn signal switches, look quite a bit different
  • back of steering wheel uses 2 cancel tabs
1964 D200 - PN 2510945 (plastic)
  • shaft is one diameter 0.750
  • uses a wire turn signal cancel @ one point
  • turn signal switch has a lot of plastic
  • dust boot @ bottom of shaft with spring retention and spring seal on shaft
So does just about any of the 61-72 Sweptline Truck turn signal switches interchange? on the electrical portion, wires look the same
Wildergarten
City: Los Gatos
Re: Turn Signal Switches - 61-64 parts
Post by Wildergarten »
jonw500 wrote:
Thu Dec 12, 2019 5:07 pm
So does just about any of the 61-72 Sweptline Truck turn signal switches interchange? on the electrical portion, wires look the same turn signal switch resized.jpg
The only one I've ever seen is on the left.
It was also used in passenger cars.
I've changed a lot of them.
Damned plastic retrurn arms break.
lube up the 61 style ts switch. its a carry over from the power giant era. its a bit more HD than plastic but they can break too if they get too dry. lube every 10 years and your good. ;/)
I have had 4 61 D300s and all have the PG era switch
jonw500
City: Hanna
State: WY
Post by jonw500 »
Wildergarten wrote:
Thu Dec 12, 2019 5:53 pm
Yay, that's what I was thinking that those arms would break off, I did find the arm pieces on eBay for sale for around $10
https://www.ebay.com/itm/Plymouth-62-66 ... 0005.m1851 or this one
https://www.ebay.com/itm/Dodge-Truck-19 ... 0667.m2042
I thought it was good that parts were reasonable and available. The metal one appears to made from a rare exotic material seeing that it's priced for NOS is crazy.
jonw500
City: Hanna
State: WY
Post by jonw500 »
Kaegi wrote:
Thu Dec 12, 2019 6:52 pm
Thank you. That's what I was thinking there was some running change when production ran outta inventory.
So clean the dirt off and what do you use for lube, dry graphite, or . . . . .? Also wondering about the T/S switch does it require blowing out or any other type of cleaning?
This one just looks so much heavier duty and I was thinking if I could keep the dirt and dust outta the top of the column things would continue to work.
Wildergarten
City: Los Gatos
jonw500 wrote:
Fri Dec 13, 2019 7:45 am
...keep the dirt and dust outta the top of the column things would continue to work.
That's the key. I'm thinking felt rings to close some of the gaps might help.
jonw500
City: Hanna
State: WY
Post by jonw500 »
Wildergarten wrote:
Fri Dec 13, 2019 9:10 am
Great idea, I like it now to find some, maybe like battery post ones
