Poly Headers
Poly Headers
Howdy, Starting the tear down on my ~64 d~100 318 Poly NP 420 trans...
Looking into headers, and wondering if anyone has installed TTI Poly headers with success?
Also wondering what problems I may run into?/? Starter, trans, Steering box etc...
Any info, advice much appreciated ~d
Re: Poly Headers
Crossmember under the bell is the biggest nightmare. That's why the poly headers designed for the swepts by Stan's are the answer.
Re: Poly Headers
Might consider these adaptors. from Bruce Toth. Use Gen 1 hemi headers and have a good exhaust shop route your pipes.
https://www.facebook.com/pg/Toth-Perfor ... 881/posts/
- Red383
- City: Fort Loramie
- State: OH
Re: Poly Headers
I went with the Toth adapters which use Gen 1 Hemi headers (331,392 Hemi). I bought the adapters and headers second hand from a guy who thought they would work on a car application. They didn't fit his car, so I got the adapters and headers for a steal.
Anyway, the adapters are nice, although they kind of block the spark plug access, and I purchased heat shield boots for my plug wires, as they would be touching the header adapters. They headers that I got with the adapters are not the greatest quality, so hopefully they seal properly.
I considered buying header flanges for the Poly off of ebay, and a set of these shorty headers for an early Hemi, and cutting the header flanges off and welding it back together with the Poly flange, but then I came across this deal.
This engine is not in the truck yet, but I think fitment will be fine.
Re: Poly Headers
Stan's Headers for the D/W trucks with the poly. These ones are ceramic coated. The clear the crossmember nicely.
1965 W200
1996 FZJ80 Land Cruiser
2019 Ram Power Wagon
- 64D100Poly
- City: Vancouver
Re: Poly Headers
I got a pair from Stan's about a month before he shut down, super high quality headers.. I also payed $800, ya get what ya pay for
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
Re: Poly Headers
when did stans shut down?64D100Poly wrote: ↑Wed Mar 09, 2022 10:08 amI got a pair from Stan's about a month before he shut down, super high quality headers.. I also payed $800, ya get what ya pay for
Re: Poly Headers
With a PTO winch shaft coming through?
Really nice engine test stand. Beautiful job you're doing.
- City: Binghamton
- State: NY
Re: Poly Headers
I don’t think they would clear the pro shaft. I am in the same boat with my truck. I fear it will get worse when the 440 goes in it.Wildergarten wrote: ↑Fri Mar 11, 2022 9:28 pmWith a PTO winch shaft coming through?
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- PowerMan
- City: Auburn
Re: Poly Headers
Yes they do clear the factory winch PTO driveshaft. Mopar Norm had these designed to fit in the D / W 100-300 with the factory winch and bellhousing crossmember. I have had these headers on my 62 W100 with factory winch and my Dad's 64 W300 with a factory winch setup. They fit the 61-66 Town Wagons as well.
Re: Poly Headers
What did Dodge use for the "factory winch"? Mine is a Braden with a 1.25" shaft. It's big, so the offset from the NP201 t-case is considerable. Did the shaft go outside the headers?PowerMan wrote: ↑Sun Mar 13, 2022 9:53 pmYes they do clear the factory winch PTO driveshaft. Mopar Norm had these designed to fit in the D / W 100-300 with the factory winch and bellhousing crossmember. I have had these headers on my 62 W100 with factory winch and my Dad's 64 W300 with a factory winch setup. They fit the 61-66 Town Wagons as well.
- PowerMan
- City: Auburn
Re: Poly Headers
Factory winch on W100 and W200 trucks were the Braden LU-2 with the 3 piece pillow block mounted drive shaft from the 10 bolt FTD-7 PTO off the NP201 transfer case. The W300 used slightly different driveshafts and mounting brackets due to the larger frame. The c-shaped frame extensions on the W100/W200 fit on the exterior of the frame while on the W300, they fit on the inside of the frame as the 300 and up frames were much bigger. The W500 and W300M used a Braden MU-2 winch.
- 64D100Poly
- City: Vancouver
Re: Poly Headers
64D100Poly wrote: ↑Wed Mar 09, 2022 10:08 amStan's Headers for the D/W trucks with the poly. These ones are ceramic coated. The clear the crossmember nicely.
About 3 months ago if i ain't mistaken
OO\===/OO
OO\===/OO
Re: Poly Headers
Mine is a Braden TD7 2D off the NP201.PowerMan wrote: ↑Mon Mar 14, 2022 8:00 amFactory winch on W100 and W200 trucks were the Braden LU-2 with the 3 piece pillow block mounted drive shaft from the 10 bolt FTD-7 PTO off the NP201 transfer case. The W300 used slightly different driveshafts and mounting brackets due to the larger frame. The c-shaped frame extensions on the W100/W200 fit on the exterior of the frame while on the W300, they fit on the inside of the frame as the 300 and up frames were much bigger. The W500 and W300M used a Braden MU-2 winch.
