For those that are running a Bronco rear tank
63d100sixer
Post by 63d100sixer »
Where did you get your filler neck hose and filler neck?
The bunch of parts I have from my many projects, and dodges, all are 2” filler hose ID. The Bronco tank is 2 1/4” ID.
What did you do to get around this?
Where did you guys end up putting the filler neck?
I was thinking behind the plate or in the bed, but my truck is a camper special and will be used to haul a camper, so I cannot block the fuel access.
Thanks in advance!
1968 D200 318 727
1972 D100 360 4 speed
1973 d100 318 727
1973 W100 440 727
