What is this in my engine bay?
fosterfarm
City: Gilroy
Post by fosterfarm »
Howdy Guys,
Admittedly I'm new to fixing up old trucks but this thing with hose spigots on it has stumped me and my brother-in-law that actually knows something about engines. What is it?
Mystery contraption
Mystery contraption
Jim100
City: Kalamazoo/MI
Re: What is this in my engine bay?
Post by Jim100 »
I have no idea but I want one.
jim
MadMC63
City: Rome
Post by MadMC63 »
Whats connected to it, where do the hoses go?
1971 Dodge D100
It filters chicken feather dander out of the oil when you operate the truck in the vicinity of chicken farms.
Hot water faucet, for making coffee.
The canister under it looks like a A/C filter drier. I don't know why it would have valves like that. Where do the other end of the hoses go?
EGroscup
City: Escondido
Post by EGroscup »
Coolant filter or more likely a block heater.
Frankenwagon
City: Independence
State: MO
Post by Frankenwagon »
I second the coolant filter.
PwrWgnDrvr wrote:It filters chicken feather dander out of the oil when you operate the truck in the vicinity of chicken farms.
Is this your "poultry" contribution..... :joker
fosterfarm
City: Gilroy
EGroscup wrote:Coolant filter or more likely a block heater.
Pardon my ignorance but what are these and how would I determine which it is?
Thanks so much for all of your help!
Look to see what its hooked into. Block, Fuel Lines ETC. Does it have a 110/120 Ac plug on it. Take some better pictures from different angles. :thinking :thinking
My W600 has a block heater which is similar looking, except for those valves.
fosterfarm
City: Gilroy
dodgeboykim wrote:Look to see what its hooked into. Block, Fuel Lines ETC. Does it have a 110/120 Ac plug on it. Take some better pictures from different angles. :thinking :thinking
Finally got to open the hood during the daylight hours. Here are some more pics:
MadMC63
City: Rome
Post by MadMC63 »
Pictures still aren't clear as to what it attaches to. the hoses disappear at the alternator. It looks like a remote filter ( oil/ fuel). If your standing directly in front of the truck and look down between the radiator and fan do you see an oil filter sticking out just below and to the right of the water pump? A remote oil filter still doesn't explain the valves though unless they were just a means to an end.
1971 Dodge D100
thehemikid
City: western kentucky
State: KY
Post by thehemikid »
My guess based on pic angles, appears there may be some T's at the water pump outlets. Seems to be a hose coming/going at a 90* there at the red arrows.
But at the green,...lot of fittings going on there making it a bit hard to tell. A pic from the blue arrow angle would help. :2cents
Not so sure how well the flow would work with a T though with flow wanting to take the path of least resistance. Could be another valve or restriction I guess, on the outlet/heater hose. I feel way out on a limb with that theory without more pics.
If its hooked into cooling system then its a coolant filter. Nothing more, Nothing less.
I saw a similar water filter on an early truck in a junkyard about 15 yrs ago, mounted on the firewall IIRC. Have pics somewhere. The valves are so you can unscrew the filter and change/clean it without draining all the fluid. Basic "isolation" plumbing concept.
fosterfarm
City: Gilroy
Here's some more photos. Is this part needed? Should I just remove it?
Get it outta there! Totally not needed, ridiculously irrelevant and useless.
MadMC63
City: Rome
Post by MadMC63 »
Definitly a coolant filter. Is your coolant really clean?
1971 Dodge D100
