Steering Wheel Blinker Cam Direction?
greggeo
Post by greggeo »
Hello Everyone.
I have a 1971 D100 . Is there a Best position for the Steering wheel Cam? Mine is a Ring that Slips onto the Wheel press on spring Style.
Should the Tripper be away from the turn signal mechanism side of the Wheel or between the turn signal Cam plastic Tripper arms?
Thanks, Greg
MadMC63
City: Rome
Re: Steering Wheel Blinker Cam Direction?
Post by MadMC63 »
My suggestion would be to place it exactly opposite of the lever. This way when you turn the wheel slightly you wont have problems actuating the switch. Its a bummer to have to sit and hold the lever because its in the cancel position already.
1971 Dodge D100
greggeo
Post by greggeo »
MadMC63 wrote:My suggestion would be to place it exactly opposite of the lever. This way when you turn the wheel slightly you wont have problems actuating the switch. Its a bummer to have to sit and hold the lever because its in the cancel position already.
MadMC63 that is Exactly where I Placed it.
Your Response is appreciated and Helpful.
Thank You,
Greg
