I bought a new steering damper for my truck as the old one had less resistanse in it than a bicyclepump:
http://www.rockauto.com/en/moreinfo.php ... 64&jsn=423
There is some instalation instructions but it is not spesific to Dodge trucks.
http://www.rockauto.com/info/Rancho/8878.pdf
Has anyone here mounted this and do you have pictures of how you mounted it?
Any hints or tips would be very welcome.
Pictures of steering damper/stabilizer mounted
- City: Ler
Gaute Halsaunet
Re: Pictures of steering damper/stabilizer mounted
I looked at solid axle setups which used a mount that clamped around the tie rod and then the mount attached to the axle. Not sure how you would keep the axle mount from sliding. Obviously you need a fixed point strong enough not to fatigue. You'll see some really nice brackets sold here that might give you ideas: http://www.ruffstuffspecialties.com/catalog/
Thank you Terry!
Thank you Terry!
