Pictures of steering damper/stabilizer mounted
Posted: Fri Aug 04, 2017 2:48 am
by Atmobil
I bought a new steering damper for my truck as the old one had less resistanse in it than a bicyclepump:
http://www.rockauto.com/en/moreinfo.php ... 64&jsn=423
There is some instalation instructions but it is not spesific to Dodge trucks.
http://www.rockauto.com/info/Rancho/8878.pdf
Has anyone here mounted this and do you have pictures of how you mounted it?
Any hints or tips would be very welcome.
Re: Pictures of steering damper/stabilizer mounted
Posted: Mon Aug 07, 2017 9:10 pm
by Conrad
I looked at solid axle setups which used a mount that clamped around the tie rod and then the mount attached to the axle. Not sure how you would keep the axle mount from sliding. Obviously you need a fixed point strong enough not to fatigue. You'll see some really nice brackets sold here that might give you ideas: http://www.ruffstuffspecialties.com/catalog/
